Rolando
Platinum Member
- Joined
- Aug 20, 2004
- Messages
- 586
- Location
- Northcentral Florida
- Tractor
- Bobcat Toolcat High Flow Turbo C-series
I'm not sure what step I should take next. As I mentioned in another post, I was having problems with the mower deck not turning sufficiently fast to actually cut the grass, and the grapple was opening slower than it was closing. The dealer determined that my unit had the copper casings defect and they replaced the 3-in-1 pump (gear pump?). After my dealer kept the Toolcat in the shop for two full weeks, I was able to use it again yesterday.
It is working exactly the same as it was when they picked it up!!
The mower deck will work with the High-flow turned on, and with my place looking like a jungle after four weeks without mowing, I went ahead and mowed with the high-flow turned on. I don't know if that will damage anything, but at this point I don't care.
Apparently, my dealership is not only incapable of fixing my machine, they don't care enough, or are too incompetent, to check that the repair actually took care of the problem. I have already complained about the service department to the dealership manager.
I can't decide if it would be best to return to the service department, the dealership manager, or go directly to Bobcat and see what they have to say? At one point I was concerned about going over people's heads and causing resentment, but now I don't see how things could get worse.
I would appreciate getting opinions as to what I should do next.
Thanks,
Thanks,
