At Home In The Woods
   / At Home In The Woods #1,771
We installed screens under our floor boards on our screen porch. Yes, some dirt accumulates, but not much since the porch is total covered. For the very small expense of screen material, and a slight increase in labor to install, I think it's a no-brainer. A bug free, outdoor room is wonderful. I power wash the porch every year or so and it gets rid of any accumulated crud between the floor boards.
thunderworks,
What kind of screen did you install? Fiberglass? Aluminum? If we can powerwash it without destroying the screens, maybe we would go ahead and put screens between the floor joists and the floor boards.
Obed
   / At Home In The Woods #1,773
I helped a close friend do this exact thing. AGAIN - since it is a totally enclosed porch - you WON'T get a lot of crap in there. During construction you will until it is enclosed, and it will require one PITA cleanup. After that, it will be pretty minor cleaning effort. But it will keep the bugs out totally.
Figure out which way you want to do it, but you need to shut off the below deck access for bugs, or you will be kicking yourself in the not-so-long-run.
BTDT. Do what you like but I have had the experience and Minnesota is mosquito land, and I'm sure your area is not much different. Fiberglass screen is dirt cheap...
-Dave
   / At Home In The Woods #1,774
Obed....We built our house 5 yrs. ago and we have a screened porch with a vaulted ceiling - 14" by 24' and we have pressure treated 2x6 deck boards for a floor and each board is about 1/4 inch apart...we have never had any bugs come in through the floor..In fact no bugs at all unless when we open a door on slips in. By the way we had each screen built in an aluminum frame and installed between the posts so if a screen needs replacing we just pop out the one panel and repair it and replace as opposed to folks wh just wrap screen around the whole structure .
Just my opinion but having been through the home building process and the fog of construction building a 4,000 sq ft brick home...this is all costing you money...every day that ticks by and it ads up. I found that as much as I wanted to add every last thing there was just too much to try and achieve ..We started construction on our house in June and moved in on Nov. 1 ...so 5 months total time to build. We have many of the goodies, bells and whistles...burgalr and fire alarm, stainless steel appliances, garanite counters, prcelan tile, hardwood floors, vaulted ceilings, house wrap, water filtration sytstem and on and on but at some point I think you will find you will have to get to the ...Get 'er done Phase...It is your money and time is money...I'm just saying ..
I haven't heard anyone who has a screened porch without screens under the floor who has bug problems. On the other hand, I'd hate to skip the screens under the floor and find out that bugs are a problem. Dilema.
   / At Home In The Woods #1,776
My friend knew folks who didn't have screen under the deck boards and had bug problems. That was why we did it on his place. This is mosquito-land here... It's cheap and easy to do. The only real downside is the potential to trap crud in there, but in a totally enclosed screened porch, there is very little crud that gets in.
Frankly it's a no-brainer to me. You have many other things that require a real decision...
   / At Home In The Woods #1,777
I told the design-build group to get all pressure treated wood 2 months in advance so it could pre-shrink, they did not do it. It was installed tight, but now there is a 1/4 to 3/16 gap on both the screened porch and open deck. Only a few mosquitos get in, but a lot more wasps get in. I hate wasps :mad:! I asked why they did not put screen down 1st, they said they didn't think about it.
The next house they did, I saw they put the screen down. I love using my money to educate people...
On the open deck, the gaps are big enough that the wasps go down under the deck and build nests. The sides are closed in.
So here's what I'm going to try: I found some sites on the web that will sell aluminum rod in various diameters, up to 12 feet long. I will buy enough in the varying sizes to drop it in the gaps. It won't be completely sealed, but will keep out skeeters and wasps. Looks like about $600 to do a deck, much more than screen but neater and no "crud hammock" effect. Will do this on the open deck, and go under the screened (because I can) and put screen on the bottom of the joists. If it gets too cruddy, I'll go the aluminum rod approach.
Doing it again, I'd do the fiberglass screen under the decking. The crud will be small (it had to get through the outside screen to get in, so it should fall back out). If you hated it, it would be easy to cut it away with a knife after the fact. You can't loose.
Pete
   / At Home In The Woods #1,778
I think I may have the decking installed without screens under the floor boards and see if bugs become a problem. If bugs become a problem, we can add screening on the underside of the floor joists later.
Obed
Mosquitoes are not so much of a problem on a second story porch as a ground level one. However, as some one else mentioned the wasps are, and here in NW Georgia so are the scorpions. Another nice thing about a bug free porch is that the door to the porch will not require a screen and that can give a nice boost in fresh air. It will also make a nice place to sleep on a cool evening.
Russ
I think we'll put screen on top of the floor joists and below the decking. Now the question is, should we do fiberglass or aluminum screens under the deck boards?
The wife was hesitant about screens under the deck boards because of collection of crud. However, she seems ok with it if we can powerwash the gaps between the boards.
Obed
2018 JAGUAR XE (A56859)
2018 JAGUAR XE...
CFG Industrail MX15RX (A53317)
CFG Industrail...
2021 Ford F-250 4X4 Crew Cab Pickup Truck (A55973)
2021 Ford F-250...
2000 Sterling L9513 Winch Truck (A56435)
2000 Sterling...
PALLET OF MISC BOAT MOTOR PARTS (A58374)
PALLET OF MISC...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
