At Home In The Woods
   / At Home In The Woods #2,251
Obed -
You're getting closer.....looking great!!
Frank
   / At Home In The Woods #2,252
Obed,
Place is looking very nice.:thumbsup:
Did the tile work get grouted yet? I was wondering if you could take a picture of that tile design you have (carpet tile) with the grout finished? Please.. No rush
Does anyone know of other names for this type of tile work. I keep trying to find more on google but haven't had any luck.
A Narrow Escape!
Guys, today has been a very long day. While moving some dirt from the back yard, the tractor got away from me and started accelerating down a steep grade.
attachment.php
I had dumped several loads of dirt in this area today driving the tractor in low gear and using 4WD. When I took a load of debris to the trash trailer, I changed to middle gear and 2WD. Then when I got my next load of dirt, I forgot to change gears back to low and 4WD. As I started down the hill, the tractor crossed a steep dip which pointed the tractor downhill even more steeply and caused the tractor to accelerate. Being in middle gear, the engine didn't help slow down the tractor and my brakes would not stop it. Keep in mind that with the hydrostatic transmission, I almost never use the brakes to slow down or stop so my reflexes to hit the brakes with my left foot may have been slower than otherwise.
As the tractor approached the end of the dirt pile, the left tires left the dirt pile and caused the tractor to lean treacherously to the left. At that moment I bailed and jumped off the tractor. Just a few feet later the FEL contacted a leaning tree fell over against some other trees this summer. The FEL slid up the tree trunk and came to a stop with both front tires off the ground.
Once I gathered my wits, I accessed the situation. The tractor did not show obvious damage so that was something in my favor. However, tractor was in an extremely tricky position that would make extricating it quite a challenge. After I jumped off the tractor I was amazed that the tractor had not turned over; further inspection revealed why. The left side of the FEL arm was leaning against a tree which prevented the tractor from tipping. That was another good thing.
However, what you can't see in the picture is the tree on the left side that the tractor was leaning against would not allow the tractor to back up; the back side of the bucket was wedged against the tree trunk preventing any reverse movement. So the tractor couldn't go forward and it couldn't go backwards. And even if it could go backwards, the tractor could possibly tip over once it got free of the tree the FEL frame was leaning against.
Things looked pretty hopeless.
I didn't have a clue how to rescue the tractor. I didn't want to turn off the tractor because the hydraulics (FEL and backhoe) were helping keep the tractor from moving. I didn't know whom to call on a Sunday at 3 PM. I didn't even know what kind of equipment would be needed and what kind of company I could ask for help. Keep in mind that the tractor was on a steep slope that would make it difficult for other equipment to reach it.
I hooked two chains together and and connected the rear of the tractor to a tree up the hill just in case the tractor tried to move. I decided to call my wife who was running errands with our dually pickup truck. There might be some way to pull the tractor out using the truck. My wife just happened to be a Lowe's when I called. She asked if I wanted her to buy a come-along. She suggested we might hook the come-along to a tree and pull the FEL sideways enough that it would be free of the tree that was blocking backward movement. So she bought the only come-along the store had; it was only rated at 1000 lbs force. She also bought two 20 foot steel cables.
While I waited for my wife to get home, I walked over to my neighbor's house to see if he could help. I asked him to bring his 4WD pickup and his chainsaw. I wasn't certain how cutting one of the trees would work but wanted to keep that as an option. When my neighbor and my wife arrived, we hooked the come-along to the tractor frame at the front of the tractor. We hooked the other end of the come-along to a tree at a 90 degree angle from the tractor. We also hooked up the rear of the tractor to our dually pickup truck using a couple chains.
My neighbor put tension on the come-along until he couldn't tighten it anymore. The FEL was failing to move away from the offending tree. Then both my neighbor and I tried to tighten the come-along when the Chinese made piece of junk handle bent 90 degrees. Things were looking pretty grim and daylight was waning.
We bent the come-along handle to as straight as we could get it. We decided to try something else. We would hook the come-along to the FEL arm, not the tractor frame. We would hook the truck up to the tractor frame near the front of the tractor. We would try to use both the come-along and the truck to pull the front of the tractor sideways. As we maneuvered our crew-cab duelly around the septic tank in the back yard, it became evident that woud could not get the long truck positioned in a useful spot. Also, we lost a lot of time trying to maneuver our long truck and darkness was close. We moved our crew-cab truck out of the way and positioned my neighbor's 4WD truck in its place.
attachment.php
While the trucks were being moved, I lifted the left rear wheel of the tractor up with the backhoe and was able to get a couple 4" blocks under the wheel which helped level the tractor. With the come-along hooked to the FEL frame instead of the tractor frame, we were able to get the FEL away from the tree that was blocking backward movement. With the FEL free, we hooked my neighbor's truck to the rear of the tractor at a 45 degree angle with the chains. Using a combination of the come-along, the backhoe, and my neighbor's truck we were able to drag the tractor back up the hill.
attachment.php
The sun was behind the hills and darkness had arrived. If our last attempt hadn't worked or took longer than it did, we'd have had to leave the tractor and find some company to free the tractor.
I'm very thankful that this stressful day turned out to be just an inconvenience and not a major mishap. I said a prayer for help to get the tractor freed. As tightly wedged against the trees as the tractor was, I'm still amazed we got the tractor out. Lots of things could have gone wrong. I'm fortunate I still have a tractor. I'm also fortune I'm not in the hospital or morgue.
Obed,
Gord,
I Googled for tile pictures looking for tile designs and saw some designs I liked. The tile guy said they were called "carpet tiles". Here's a place I got some ideas Flooring Design Gallery - Kitchen Tile Ideas by SouthCypress.com.
I'll take a picture of our kitchen tile with the grout installed and post it for you.
Obed
   / At Home In The Woods #2,258
Obed,
Glad to hear you got the tractor free without damage. I think part of your issue was trying to hook the come-along too low on the tractor. Leverage is your friend in this type of situation.
My first thought when reading your posts was to hook a come-along to the ROPS just above the fender and at a 90 degree angle to secure the tractor from rolling. Then use the backhoe and outriggers to level and reposition the tractor.
Another point to bring up here is that on a run-away tractor with a FEL, you can drop the bucket and begin uncurling until the front of the bucket begins to grab dirt and provide braking for the tractor. The cutting edge on the bucket digging into the dirt does a lot to stop the tractor from moving.
Again, glad to hear that everything worked out OK.:thumbsup:
Obed,
Cyril,
Good observations. Yes, leverage worked once we hooked the come-along to the FEL arm that was higher than the tractor. I didn't think about using the FEL as a brake. Good idea.
The whole episode just took 2 or 3 seconds from start to finish ... plus the 3 hours it took to retrieve the tractor. Now that I know about the FEL braking trick, I might be able to use it. However, I hope I never need that trick in the future.
Obed
   / At Home In The Woods #2,260
WOW!
I am very happy to hear that you and the tractor made it out OK.
Well, I learned something from this also. I have a steep driveway, and I have been in the habit of going down it in high gear and 2 WD. No more. 4 WD everywhere, and no higher than middle range.
P.S. While dropping the FEL will provide extra braking power, lowering the cutting edge is sort of a crapshoot. I haven't had to use it as a brake, but from experience scraping up dirt, there is a critical angle--too little down angle and the blade just skims the surface, too much and it digs in and wants to keep going down. This could cause a very abrupt stop. While I have never head of a forward flip over from this cause, I think a runaway tractor and a sudden stop with the FEL buried in the earth might cause one.
2005 CATERPILLAR 262B SKID STEER (A52709)
2005 CATERPILLAR...
2114 (A58376)
2114 (A58376)
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
Hose Reel (A55758)
Hose Reel (A55758)
3-5TH WHEEL PLATES (A58216)
3-5TH WHEEL PLATES...
Terms & Conditions of (Buying through EquipmentDealz Auction) Continued (A59213)
Terms & Conditions...
