Rod in Forfar
Platinum Member
- Joined
- Apr 10, 2010
- Messages
- 569
- Location
- Forfar, Ontario, Canada
- Tractor
- 1960 Massey Ferguson 35 (Perkins), 1995 TAFE 35DI, 1980 Bolens G174, 2005 Kubota B7510, 2020 Kioti Mechron 2200ps UTV Troy-Bilt Horse 2 1988 Case IH 255 4WD with loader and cab
The auger wasn't engaged when I slipped off an icy road and slid backwards into the ditch, hitting the auger full-on, though not very hard. The spiral parts of the auger weren't damaged, just the centre shaft, which was deflected almost an inch. Before I put the blower away I tried to pry the shaft back straight with a small floor jack and a large wooden block. The 2600 lb. jack had no effect upon the sturdy shaft.
I ran the pto up on the 35 hp tractor and it doesn't seem to vibrate much. Would it be best just to use it the way it is, get a new auger shaft, or get the original repaired?
Thanks,
Rod
Thanks,
Rod
