schmism
Super Member
So my $500 livestock trailer. Needs some rebuilds
I figured id make a thread for the trailer, and a thread for the axles as the axles are rather independent of the trailer type and we have seen some other rebuild candidates come across the boards in terms of suggestions.
The trailer is a 92. You start with rusty wheels/lug nuts that do not look like they have been off for 20 years.
My impact had a hard time running them off across all the rust so on the second wheel we busted out the gas axe and heated the lugs. (just slight color) Then the impact ran them right off.
the drums spin freely and nicely, no horrible sounds, no wobbles... Although i do have my suspicions that the trailer sat in a flooded area at some point due to the even coat of mud inside all the rims, inside the box were they tied the brake wireing together, etc.
I have been unable to move any of the moving parts on the backing plates that operate the brakes. Magnets are worn through, shoes look virtually untouched. I just dont think the trailer had that many miles on it due to the condition of the shoes/drums and the bearings.
Again the torch on the backside backing plate bolts reduced the required work significantly. Due to tight space this is a hand job only, no air tools will fit back there.
The axle backing plate area was wirecupped (4.5" angle grinder), primmed with rusty primer and a quick shot of black. Spindle was tapped off. The tires were wire wheeled on the front, coat of rusty primer, then 2 coats of white. Backsides got hit with a wire wheel and some primer only.
Bearings were cleaned in my parts cleaner, blown dry, and repacked with grease. inspection of both bearings an races were good. grease that came out of hubs was 90% ive seen much worse.
So to the meat n patatos
Priceing parts for my 6 on 5.5 5200-6000lb axles.
shoes are ~$25 magnets are ~$25
-all new backing plates with everything installled is $43 ?!?!?!
- new rear seals ~$4 ea
- new mounting bolts for backing plates
- new lug nuts.
hardware per wheel ~$5 (lugs, backing plate bolts)
I also purchased a new 1/2"x20 die to chase threads on the drums.
By the time you add up primer, spray paint, new can of axle bearing grease, brake clean etc...
~$60 per tire for a brake rebuild reusing old bearings, drums and tires.
a drum with bearing and seal set is ~$82
a bearing set alone is ~$10
tires run $140-160
you need the whole enchilada? (drum with bearings, backing plates, tires?) ballpark $600 an axle.
- new lug nuts.
tires run $140-160
