sandyc
Veteran Member
I was using the FEL to remove a small stump. Dumped the bucket so I could short chain the stump using the chain hook on the top of the fell before I hooked up the chain the dump went into detent and wouldn't stop until it had reached full dump. I could curl the bucket up but could not dump it again. The FEL control lever couldn't actuate the fel dump valve. checked for obstructions and found none. the control lever will raise and lower the fel but has no affect on the curl dump actions. looks like the valve has something jammed in it. Left an email for my dealer's service dept as I am guessing I need a new valve. Believe the warranty is up so I am SOL....my 14' single axle trailer won't haul the tractor with the FEL, loaded tires, and BH subframe. I guess I could drive the ten miles on the roads but am a bit reluctant to do so with all the tourist traffic this time of year......
