B2320 - how to take off dash plastic cowling
   / B2320 - how to take off dash plastic cowling #1
HCamp
MX5100, B2320
Yesterday I mowed with the B2320 for several hours, turned off the engine for an hour or so, and when I returned to start the tractor up again nothing, no clicks or any other sound or lights on the dash when I turn the key, and no headlights/turn signals when I try the light switch. Battery is fine - I can crank the engine by shorting the starter solenoid terminals, and cranking speed sounds normal, but it won't start, I assume probably because of a stop solenoid on the fuel pump. All the fuses in the fuse box by the starter are good.
Next I was going to check the key switch which is mounted on the big plastic cowling. I have a puller for the steering wheel, but I only see one attaching screw on the center top of the cowling and don't see how it comes off. Would appreciate info from anyone who's done this!
Thanks much,
Howard
   / B2320 - how to take off dash plastic cowling #2
I don't know if ours are set up the same, but my 2650 has 2 bolts down at the bottom of the cowling that need to be taken out.
Joe
I'll check it out. Thanks much!
Howard
2018 Dodge Ram 5500 Bucket Truck - 4x4, Versalift VST40, 45FT Reach, Dakota Line Body (A51039)
2018 Dodge Ram...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
SDLG WHEEL LOADER FORKS MAST W/ 48" FORKS (A51242)
SDLG WHEEL LOADER...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
