B3200 HST Pedal Vibration?
   / B3200 HST Pedal Vibration? #11
Well I've had my B3200 for a little over a week now and today I finally had the chance to get more than 30 minutes of seat time. I too have major vibrations at PTO speeds. Its quite terrible if you ask me. I feel its unacceptable for a new machine. I can feel the vibrations literally through every aspect of the tractor. Now this is with nothing attached to the PTO and with a loader and rear blade.
   / B3200 HST Pedal Vibration? #12
I have a B3200 with about 10 hrs on it and it vibrates also at higher RPMs. I have read and read posts on TBN about this issue with the 4 cylinder Kubota engines. You would think that an equally opposed 4 cylinder engine would be smoother than a 3 cylinder...go figure. From what I have heard on TBN you just have to try to find the "sweet spot" where vibration is at a minimum and live with it. I would let your dealer know, though...I did.
   / B3200 HST Pedal Vibration? #13
I had a B3030 hstc i ran from 2005 to 2008, i never had any of these issues. I sold that machine to a member here at tbn and he has never had the vibration issues either?
   / B3200 HST Pedal Vibration? #14
You're right King, I don't feel any vibration in my 3030. I'd be interested in trying out one of these vibrating tractors to see if its just me thats numb (my wife says I am! :D). I sometimes wonder if a lifetime of driving trucks makes me not notice, where someone else who drives a Lexus back and forth to work, and works in an office, feels a tractor vibrate.:confused:
   / B3200 HST Pedal Vibration? #15
I would have to say that I have the vibration in my b3200 as well but because I have run some real ruff stuff over the years it does not bother me. I just run it at a comfortable rpm. Granted I would rather have it be smooth (much less bolt loosening).
   / B3200 HST Pedal Vibration? #16
Mine vibrates as well but I did a few things that seem to help a bit, especially the noise. I tightened all the bolts on the fenders and floor. It made them feel a little stringer as well. I tightened the screws on the plastic control lever guides, one of which had been stripped so not much I could do. The biggest noise maker is the top link clip when not in use. I ran a small bungee cord from the hole in the thin back guard to the clip. Mostly this helped with the noise but the one fender was actually a bit loose so this helped a bit with the vibration.
One other thing to try, clamp or bolt on some weight to the HST peddle. This will change it resonate frequency.
Russ
   / B3200 HST Pedal Vibration? #17
My B3200 is the same once over 2000 RPM it starts to vibrate and at PTO speed which I rarely use it really vibrates! I am going to ask the dealer about this when I get my 50 hr service done here soon. I have never owned a tractor before....but I have owned many machines w/ engines, bikes, ATV's, outboards, jeeps, trucks, cars........and I have never experienced this excessive vibration before in anything I've ever owned. I'm not complaining to bad yet but I can see the guy who uses the PTO all the time be a little frustrated :).
2013 Ford F-150 4x4 Pickup Truck (A55852)
2013 Ford F-150...
2016 Ford Escape SE SUV (A55853)
2016 Ford Escape...
HYD TRANSFER TANK (A57192)
HYD TRANSFER TANK...
2013 Infiniti JX35 SUV (A55853)
2013 Infiniti JX35...
2008 Chevrolet 2500HD Silverado 4x4 Crew Cab Pickup Truck (A55852)
2008 Chevrolet...
ATTENTION PLEASE READ (A56469)
ATTENTION PLEASE...
