Verticaltrx
Veteran Member
- Joined
- Dec 30, 2009
- Messages
- 1,908
- Location
- VA
- Tractor
- Kubota B3200/L2501/SVL65-2/U35-4, IH 454/656, Ford NAA, Case 1845C/480E/450C LGP
I'm back to thinking about adding a couple SCVs to my B3200. I would like to use a standard, compact, 2 spool valve, open center. I would just install it 'in-line' in the pressure line that goes from the loader valve to the 3pt hitch. i.e. loader valve power beyond port > in port on valve, out port on valve > in port on three point hitch.
I know the way it 'should' be done is to use a power beyond capable valve and run it to the 3pt hitch (and have a low pressure return line), but would I damage anything by doing it my way? I can't see any disadvantage except that I wouldn't be able to lift the 3pt and operate the valve at the same time, which I would never do anyways.
Thoughts?
Thoughts?
