B7100 fan quit spinning
   / B7100 fan quit spinning
As for the rest the only thing 12 volts is required for is starting. Everything else is mechanical.
wow, that is awesome. these machines are insanely simple. thanks for the heads up!
   / B7100 fan quit spinning #12
What sort of fuel shut off valve does the tractor have? Is electrical or mechanical? kt
   / B7100 fan quit spinning #14
OK, just to make sure I have this clear. I am experiencing the same issue on my 94' B7100HST. I removed the radiator and belt and manually turned the fan/dynamo until it started moving freely again. Based on your discussion I am assuming 1 of the following:
1. Debris somehow got caught up in the dynamo which caused it to freeze up, possible but maybe not likely?
or
2. The bearing has frozen and needs to be replaced, which may be the most likely case I am guessing.
If scenario 1 is true then I will have no further issues, but if not, then my battery will eventually die unless I charge it ever so often or at least put it on my battery maintainer.
It did not take too much effort to get it moving again by hand, so if it was a bearing problem should it have been significantly harder to get it moving again?
At this point can I assume, now that my fan can turn freely, that I should not have to worry about my tractor overheating any more? and that I can continue to use my tractor until I can either replace the dynamo or upgrade it to an alternator?
Thanks for the help on this.
   / B7100 fan quit spinning #15
[At this point can I assume, now that my fan can turn freely, that I should not have to worry about my tractor overheating any more? and that I can continue to use my tractor until I can either replace the dynamo or upgrade it to an alternator?/QUOTE]
Don't count on it. As soon as the bearing heats up it may seize again. Without the fan the tractor will overheat.:D
Mobile Mud Hog (A56469)
Mobile Mud Hog...
2025 John Deere 1025R (A53317)
2025 John Deere...
2017 INTERNATIONAL 4300 21FT BOX TRUCK (A57880)
2017 INTERNATIONAL...
2018 John Deere 30G Mini Excavator (A56857)
2018 John Deere...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A55315)
Adams Load Out...
2014 Ford F-250 4x4 Ext. Cab 8ft. Flatbed Truck (A55852)
2014 Ford F-250...
