B7100 Front axle fill level
   / B7100 Front axle fill level #1
AlanB
Elite Member
Clarksville, TN, USA
NH 1925
I searched and could not find a specific answer, and I have the IT manual and it tells me the volume, but I would rather just check it.
I just bought my father a well used B7100 gear drive, 4wd tractor. I want to check the fluid levels in the front end (3pts) and I have pulled the fill plugs and nothing comes out nor is it visible. I would rather not have to drain and refill them all.
What level is "full"? Should I be able to see the gear oil through the fill plug hole? Is there a different level plug that I am missing or something?
Thanks for the help.
Alan Bechard
   / B7100 Front axle fill level #2
Best to drain them and then refill. It doesn't take long and is very easy.
When I do mine I fill till they are full which is quite a bit more than called for.
Egon
   / B7100 Front axle fill level #3
Hi
Front axle case oil = 0.7litre of oil
Left & Right axle gear case oil = 0.15litres in each
the above according to the operators manual,
hope this helps
Mat
   / B7100 Front axle fill level #4
Alan,
I have also tried to find an answer to this question but have been unsuccessful. I induced a leak in the front seal of my B2150 going down the road wide open in 3H, I forgot to take it out of 4WD. I had not had a leak until then. I have to top off occasionally. The owners manual doesn't give any direction on this. I just add to the bottom of the neck.
Which brings up the question: If overfilled will it cause the seal to leak at a faster rate? I'll let you know if I find out anything.
Sorry I had not responded back here. It is my dad's so figured as mentioned above, just do it, do it right, change it out and be done. .15 L is nowhere near the bottom of the fill plug, I would think overfilling it like that could potentially cause problems as well.
Fresh 80/90 in all three area's and it got rid of the noise it was making.
Thanks folks.
2013 MACK CHU613 (A50854)
2013 MACK CHU613...
1240 (A50490)
1240 (A50490)
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2006 Peterbilt 379 T/A Sleep Cab Truck Tractor (A49461)
2006 Peterbilt 379...
BUYERS PREMIUM & PAYMENT TERMS (A51222)
BUYERS PREMIUM &...
utility bed (A49461)
