B7100 Hydraulics Question
   / B7100 Hydraulics Question #11
Well, color me impressed! ;) I finally got around to testing my b219 loader on my b7100. It picked up 18 bags of pellets, 40lbs each at mid throttle.... thats 720 pounds. I ran well out of bucket, had the bags stacked on top etc. It definitely knew the load was there but probably could go another couple hundred pounds. Did not try driving it around but had the hoe on and it never felt 'tippy' while lifting. Also have filled tires.
Charles
   / B7100 Hydraulics Question #12
I have the same setup as a lot of you guys, front pump running FEL (rear PTO pump running BH). I don't really think this is aftermarket by the looks of it. My FEL works fine but I don't believe both functions will work simultaneousy.
Didn't even know there was an engine pump!
Anyone know how many psi the pump should be putting out? Mine is putting out just under 1100 psi, is that enough?
   / B7100 Hydraulics Question #14
Amity,
For the LA219, the specs on the relief is 800 PSI - the loader should lift 610 lbs.
Pump specs are 4.7 GPM @ 2800 RPM.
Good luck!
2015 VOLVO VNL SINGLE AXLE DAY CAB (A51222)
2015 VOLVO VNL...
2022 Adams CLC-1013 Conveyor - New (A51039)
2022 Adams...
1994 PETERBILT 379 SLEEPER (A50046)
1994 PETERBILT 379...
2015 DODGE RAM...
2020 John Deere 870GP Articulated Motor Grader (A49461)
2020 John Deere...
ASSET DESCRIPTIONS & CONDITION (A51222)
ASSET DESCRIPTIONS...
