3-Point Hitch B7200D Hydraulic Contol Lever
   / B7200D Hydraulic Contol Lever #1
cfinkle
San Martin, Ca.
Kubota B7200D
I've recently have had my Hydraulic Pump replaced and all has been fine until now. I'm hearing a noise and I also can feel a gear grinding vibration in the Hydraulic Control Lever when raising the box scraper implement. My owners manual just states that the Hydraulic Mechanism is not adjusted properly, and that if a dealer doesn't correct it the unit will be damaged. Does anyone know what Hydraulic Mechanism adjustment that is needed to correct my problem. Thanks in advance.:):)
I finally broke down and took the tractor to a dealer for his opinion. They fixed my problem for under $100.00 and stated that I was always missing part number 67401-0369-0 (Ring) in my Control Valve. I'm not a mechanic but it seems to me that they should have discovered this problem when they did a hydraulic pressure test. It was after the hydraulic pressure test that the dealer told me that the hydraulic pump needed to be replaced. I have purchased this Kubota used and I don't have all of the mechanical history. I hope that this information can help someone else and good luck.
   / B7200D Hydraulic Contol Lever #3
Thanks for post of problem and solution.:thumbsup::thumbsup::thumbsup:
2016 Chevrolet Silverado (A57148)
2016 Chevrolet...
2016 KOMATSU PC360LC-11 EXCAVATOR (A58214)
2016 KOMATSU...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
Payment Instructions (A55272)
Payment...
Giyi Auger (A57149)
Giyi Auger (A57149)
2129 (A58376)
2129 (A58376)
