B7500 HST power steering and and 3 point lift problems in high temp.
   / B7500 HST power steering and and 3 point lift problems in high temp. #51
I have a B2400HSD. My tractor does not appear to be plumbed as shown with the return line going directly into the main line. I could be mistaken but this does not seem to apply to my problem. Again, since I've been using AMSOIL hydraulic fluid, with the exception of the first 2 or 3 mowing jobs, I've had zero problems. In the past I used UDT, Super UDT, Bobcat fluid, and TSC fluid. When I was using any of those fluids, after an hour of hard mowing, I would completely lose the power steering when I made any left turn. Thank heavens for the AMSOIL.
   / B7500 HST power steering and and 3 point lift problems in high temp. #52
Hey tomf...what Amsoil are you using? thanks
   / B7500 HST power steering and and 3 point lift problems in high temp. #53
   / B7500 HST power steering and and 3 point lift problems in high temp. #54
Tomf
You can try and raise your system relief pressure. or it also sound like a gear to housing issue with your pump (worn out) but if it only happens to a left hand it almost sound like a steering valve problem. probably should start with checking your system relief pressure.
UNUSED FUTURE X-PG44" HYD MINI PLATE GRABBER (A57193)
UNUSED FUTURE...
MCCORMICK T110 MAX TRACTOR (A57192)
MCCORMICK T110 MAX...
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
(7) 12" X 22# X 171" (2) 12" X 22# X 15.5" I BEAM (A57192)
(7) 12" X 22# X...
2020 DRAGON ESP...
2024 FORD F250 SUPER DUTY BED (A57880)
2024 FORD F250...
