Bad diesel exhaust fluid?
   / Bad diesel exhaust fluid? #1
w7dms
Sandy, Ore.
MF1531
does def go bad, if so how do you tell that it is bad. then what do you do with it?
   / Bad diesel exhaust fluid? #2
Yes, diesel exhaust fluid (DEF) can go bad if it becomes contaminated or if it is stored improperly. It is recommended to use DEF within one year of purchase and to keep it in a cool, dry place away from direct sunlight to maintain its effectiveness.
Probably by the production date. If it’s more than a year, don’t use it. If the jug has been sitting open long term, don’t use it. If sitting outside in the sun, don’t use it.
   / Bad diesel exhaust fluid? #4
If you buy jugs, ALWAYS make sure the seal is intact before opening. Years ago there were reports of WalMart jugs refilled with water.
thanks to all for your help. i bought a 250 gal tote with about 100 gallons of def; at an auction. but it had a pump system on it that i wanted, so i made out ok.
   / Bad diesel exhaust fluid? #6
2012 Big Tex 14ET-20BK 20ft T/A Flatbed Trailer (A55852)
2012 Big Tex...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A55314)
2019 Krause...
2014 Dodge Charger Sedan (A55853)
2014 Dodge Charger...
1995 CATERPILLAR 928F WHEEL LOADER (A52707)
1995 CATERPILLAR...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A55314)
2022 Brush Wolf...
CURTIS 55CFM AIR COMPRESSOR (A54757)
CURTIS 55CFM AIR...
