Barndominium/Shop or "real" House?
   / Barndominium/Shop or "real" House?
Banning Natural Gas has to be one of the most ridiculous things ever!!!
I sure hope you can get your line installed before it's too late.
I'm sure what will happen is once the ban starts there will be some lawsuits that will be taken all the way to the Supreme Court and then reversed. But I'd like to get mine installed before all that BS happens.
One thing I had the Amish crew do was to trim out the interior openings of the overhead doors with white steel so that I'm not having to remove door tracks, springs & shafts when I want to finish those areas off. OH doors should be installed soon.
   / Barndominium/Shop or "real" House? #493
That inside photo sure shows how big it is!!!!!!
   / Barndominium/Shop or "real" House? #494
Around here, zoning applies and any 'barndo' structure has to be built to BOCA standards if the living quarters is integral to it.
In my state BOCA was replaced with ICC standards. The architect who stamped my plans had to perform a fire code review on my design. The living space has to be separated from the shop area with fire rated doors and drywall. So I can't have any steel on the inside of the garage, nor the walls inside the shop adjacent to the living space. Rest of the shop can be steel panels on the walls and ceiling.
   / Barndominium/Shop or "real" House? #496
What does steel do during a fire? I don't understand why it's bad.
Pretty sure drywall has fire retardant in it. The steel heat transfer to the wood behind it would be pretty much instant.
Having said all that, the difference between the two is unlikely to actually save the building. But maybe time enough for people to escape.
   / Barndominium/Shop or "real" House? #498
ETD66SS indeed this is big!
I forgot the dimensions is this 40 W x 100 L total and the "house" area is 30x40? Can you repost the plan again?
It's 48 x 96 with 18.5ft tall walls.
The living space is about 26 x 48 with a room above the workshop space that is about another 20 x 20. About 1700 sq-ft of total floor heated living space.
   / Barndominium/Shop or "real" House? #500
Thank you - you are building an amazing space or place with the shop, house, barn, all under one roof!
Also I know you mentioned solar, is that still in the plan for the roof? Best to get all this in place now as part of the plan - at least the wiring conduit and lines for Mini Splits for AC and or heat. I know you plan on NG for heat but best to plan with options to future proof your hvac options.
New/Unused CFG Industrial NT18K Mini Excavator (A57453)
New/Unused CFG...
New/Unused 200lbs Cast Iron Anvil (A57454)
New/Unused 200lbs...
2007 Tymco 500X Air Sweeper, Turbo Diesel, 3876 Hours Indicated, mounted on 2007 International 4200 (A59076)
2007 Tymco 500X...
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
2012 Ford Transit Connect Cargo Van (A56858)
2012 Ford Transit...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
