Best 1" ratchet straps?
   / Best 1" ratchet straps?
The 1" straps I use are rated for 1000# WLL, 3000# breaking strength. I won't buy anything lighter as the metal of the ratchet bends like a cooked spaghetti noodle...
Aaron Z
I've never had that issue. Even the straps I've had that are have flimsy strap material that wears/abrades fast have had solid ratchets.
Rob
   / Best 1" ratchet straps? #32
Rob
I have. When you’re already abusing them it’s fairly easy to break a ratchet on the cheap straps. I have plenty of cheap straps laying around with busted ratchet and a good strap.
   / Best 1" ratchet straps? #34
One and done. Only the BEST. Mac's custom tie downs. Everything is US made, and they can configure them however you want. I use these daily in the towing industry, the "free spool" ratchets are pretty trick.
Professional Tie Down Systems for Any Vehicle
I see them all the time at the Good Guys car shows, they really do hang the car and trailer in the air with a crane, using their straps. :)
   / Best 1" ratchet straps? #35
I have lots of them around but if I was going to order some I think I would go with Strapworks. They have an option for a stainless ratchet. The problem I've always had is that if you use them in the rain or snow after a couple years the metal starts to rust or corrode and the ratchet no longer works smoothly. Sucks to be fighting with a ratchet in the rain while trying to tie something down.
   / Best 1" ratchet straps? #36
That looks pretty good. I might order a couple for tying down my mower. I usually use 2” straps for most things but I like having a few good 1” straps around. Sometimes the hook on a 2” is just too big.
4570Man, did you buy and have a chance to use them yet?
   / Best 1" ratchet straps? #37
Yes I have to say I’m not impressed. They’re good straps, but no better than the better orange straps at tractor supply that cost nearly half as much. They are longer then the TSC straps if that’s important to you.
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
198367 (A51243)
198367 (A51243)
2005 Nissan Frontier Crew Cab Pickup Truck (A55852)
2005 Nissan...
2001 BOMAG BW141AD-2 SMOOTH DBL DRUM ROLLER (A52707)
2001 BOMAG...
2024 78in Hydraulic Brush Grapple Skid Steer Attachment (A55851)
2024 78in...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
