Best NEW 6 ft. rotary cutter [chopper] for under $1500.00
   / Best NEW 6 ft. rotary cutter [chopper] for under $1500.00 #1
wbyman
Title says it all. I am looking for a new 6 ft. rotary cutter for under $1500.00. What is everyone's opinion ?
   / Best NEW 6 ft. rotary cutter [chopper] for under $1500.00 #2
My guess is that you can get a light duty one for a little less than $1500.00, but not a medium to heavy duty one for that money. I bought a light duty 6 footer at the Co Op a couple of years ago for under $1000.00. I cut about five acres of grass only 4-5 tmes a year and so far no problems with the light duty model. If you are cutting areas that haven't been attended for a few years with saplings etc., you probably need to spend a little more and get a heavier duty cutter with a slip clutch. That's my $0.02 worth.
   / Best NEW 6 ft. rotary cutter [chopper] for under $1500.00 #3
I suggest you call around dealers to see what the prices are. My guess is you might find a King Kutter or Howse for $1500 or less.
   / Best NEW 6 ft. rotary cutter [chopper] for under $1500.00 #4
My Hawkline 6-ft brush hog cost $1150 when I bought it in 2008.
   / Best NEW 6 ft. rotary cutter [chopper] for under $1500.00 #5
i saw a 6' countryline at TSC today for $less than $1100, if i'm not mistaken.
not sure about the quality. looked stout to me.
   / Best NEW 6 ft. rotary cutter [chopper] for under $1500.00 #6
How many horses does your tractor have? Reason I ask is I bought a 6' Massey brand rotary mower a few years back to cut an orchard for a neighbor. With only 32 horses I often found myself running in 1st gear. I got lucky and sold it to a friend for a $250 loss.
When shopping look a how heavy the gear box is. Deck guage thickness. I bought a Bushog brand 5' Squealer. It is nice. I really like the smooth top. Easy to clean when the day is done. Other rotary mowers I owned had the supports welded on top of the deck which caught the clippings.
   / Best NEW 6 ft. rotary cutter [chopper] for under $1500.00 #7
TracTrac is right, you need to consider how much HP your tractor has. But to answer your question, the King Kutter L72-60-HD is a fairly heavy duty cutter for that kind of money. The Fred Cain AC106SSC and AC206SSC are also stout built cutters in that price range.
I have a JD 4005 = 41.5 hp. I found a Rhino light duty for $1250.00 , I think it is the rx model, cuts up to 1" stuff. Thanks for the answers.
   / Best NEW 6 ft. rotary cutter [chopper] for under $1500.00 #9
Take a look at modern ag out of Texas the have several models the decks are thicker 3/16" and you can even get some hot dipped galvanized with a ten year rust warranty all for under 1500
I am having a dealer bring one in for me. They sure look stout to me but have only seen them on Internet they have been around since 60's. Made in USA putting people to work. All good things check them out.
   / Best NEW 6 ft. rotary cutter [chopper] for under $1500.00 #10
They definitely look heavy duty...got the weight to substantiate the "heavy duty" too.
Link
TEST YOUR BID BUTTON! (A57192)
TEST YOUR BID...
UNUSED FUTURE 32"...
CATERPILLAR 279D SKID STEER (A52707)
CATERPILLAR 279D...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2018 Chevrolet Tahoe (A55973)
2018 Chevrolet...
