whitepine2
Can you get a gear puller on this blower if not make one up that will help to remove.
Kroil is the best !!!
No it aint the best, Gibbs is better,been using both for years and although kroil is good Gibbs better. Have you used Gibbs try it you will like.
Where do you buy Gibbs locally?
How would I make one? I have maximum 3/4 inch between the back side of the fan and the blower housing. Plus, I need six inch spread (3 inches each side of center hub).
I want to do this right---I want to re thread the stripped threads on the gearbox oil fill. To do that, the gearbox has to come out so I can take it to a machine shop.
Also, I will re-assemble everything with anti seize should I ever have to take it apart again.
White pine,If gear box needs to come out might as well use heat and if seal goes bonka replace the seal. Why cant you run a tap to fix the threads. Just fill the flutes with heavy grease this will catch the filings,if
this don't do it re-drill it doing the same thing fill drill flutes with grease then re tap using grease in tap flutes this should work has for me. Is it pipe thread,most are and use a pipe plug?
