Best way to remove saplings
   / Best way to remove saplings #11
I have about an acre that has a lot of 2" oak and Sweetgum trees as well as a LOT of 1-2 inch wild pear trees. What is the best way to clean this up. I tried chemicals on the wild pear saplings but they always seem to come back. I would like to take care of this problem so that I don't have regrowth. I have a 3930 new holland and a Gannon blade. I seem to recall there is some type of grabber that you can get to pull up the saplings but this seem like it would take a long time. Thanks
Check this tree puller thread: http://www.tractorbynet.com/forums/attachments/277824-tree-puller.html
The advantage of pulling is, no stump, very small hole after you shake the dirt off of the roots.
   / Best way to remove saplings #12
Used my Grubber on a 3/8 chain hung from bucket hooks tonight to see how hard it would be to use. It pops them out of the ground fairly easy, but need two people to be effective. Realizing I need a box blade or weight box on the back. Got a rear wheel in the air a couple of times. At that point I just put the bucket really low and drove forward and they popped out. I would recommend going forward versus back cuase when the tap root lets go it does so with a POP. Going backwards may put the thing through your grill.
Pulling 6-10in ponderosa stumps cut at 12-15in tall.
   / Best way to remove saplings #13
I'd choose the method based on what I planned on doing with the field afterword.
If you just want to clear it to be pasture or whatever, bushhog it.
IF you want to farm it, the roots may be an issue.
But sounds like alot of oak trees that are the perfect size for transplanting. I hate wasting good oaks. In my area, 2" oaks bring 60-70 bucks at greenhouses. Why not put an ad up on c-list or something and let people dig them out for like 10/ea or something??
   / Best way to remove saplings #14
I agree it all depends what you are planning on doing with the field.
You could use a trimmer with a brush cutting blade. You could probably almost cut them off flush.
   / Best way to remove saplings #15
I have done a lot of this method. You will get 95% of the roots too. Works great on pine/fir/spruce, poplar, ash, maple, red oak a bit tougher. Works poorly with beech I've found. So, it is species dependent, and ground moisture makes a difference too.
I would certainly give it a try before spending money on additional tools.
I'm for the tooth bar too.:thumbsup:
One acre will not take that long.
   / Best way to remove saplings #16
A tooth bar would be nice, but I don't have one. My bucket has a removable cutting edge that stays very sharp from back dragging though. The cutting edge bites into the trunks enough to get a grip.
   / Best way to remove saplings #17
Unless you have a backhoe or a FEL shovel attachment, hooking a chain around them and pulling them up by the roots is the best way to go especially with the sweet gum trees. ANY amount of root left is going to sprout out a tree, but these can be dealt with via chemical spraying (2-4D) or just mowing them down each year. Thorn trees are the worst for sprouting and also have the most tenacious root system. I found a couple of them growing outside my fence line in the road ditch right of way so rather than cut them with my weedeater with Gator head attachment, I took my B26 out and dug them up with the back hoe. They were about 20 feet apart and all on a connected root about 4" in diameter with all kinds of root spurs coming off. Nasty rascals to control.
I had a section by my creek that was about 60 feet wide by 800 feet long that was very thick with sweet gum trees that I used my tractor and bush hog to push over and shred up as much as I could get into the thicket which worked fairly well till I got too many large trees in the way but it did thin out along the edge. After about 3 years of mowing most of the stubs had died and rotted out. I also used my RTV 900 and a chain to yank out a bunch of the smaller ones which got a lot of them thinned out. This was a lot of work, hooking, pulling unhooking etc but it was still faster than digging them out with the FEL and it left much smaller holes.
After I got my B26 TLB, I made a half day clearing out and thinning enough that I could get my tractor around thru them. I didn't want to take all, just enough to allow some light to get to the bottom so some grass could grow. I just backed up into the thicket, popping them out left, center and right, then used the backhoe thumb to drag them to the side and stack them, then backed in for another round. About 6 hours of this and I had almost all of what I wanted to remove on the ground, then it was just a matter of pushing everything into a pile for burning later. A backhoe is an expensive attachment, but I wouldn't be without mine. I just wish I had bought one 4 years ago rather than last year. I have not only cleared sapling growth, but dug up dead and live pines trees from sapling size to greater than 20" diameter at the butt end, dug up rocks both large and small, dug pits for burying dead animals, mucked out ponds and creeks to remove trash and make deep holes in my creek so they stay wet year round, hauled dirt to fill in holes, etc. Just tons of uses for a TLB but only if you can justify the upfront costs with a substantial amount of work.
   / Best way to remove saplings #18
The cutting edge does work. I've cleaned out quite bushes/trees with a Kubota B7100 and smooth edge bucket. Actually wore out the cutting edge and had to replace it.
   / Best way to remove saplings #19
I have shredded a place where had a bunch of little sweetgums,then went in with boxblade, set the rippers out and ripped the little stobs up,smoothed back out with drag harrow. Then went in and sprayed with 2-4d/remedy mix,when a few showed back up.
   / Best way to remove saplings #20
I push over up to 4" alders by setting my BX25 FEL about 4' high and push as far as I can, that gets the roots loose on that side then either push the other side the same way or get the FEL blade under the exposed roots and curl up. Works every time. I then drag them to the wood lot in 4-6 bundle wrapped with chain hooked to the top of the QH and lifted off the ground.
Ron
8' Offroad Army Wagon (A56469)
8' Offroad Army...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56435)
2017 Yale GLC050VX...
UNUSED WOLVERINE BSH-12-75D BALE SQUEEZE (A57193)
UNUSED WOLVERINE...
7021 (A55851)
7021 (A55851)
2021 SAVANA 4500 BOX TRUCK (A57880)
2021 SAVANA 4500...
AGT SAII100 SKID STEER QUICK ATTACH 48" (A57193)
AGT SAII100 SKID...
