Blacktop or Concrete driveway?
   / Blacktop or Concrete driveway? #11
Exactly. I should add that the hole is due to the loader and then the snow blower on the tractor. When I used a walk-behind snow blower it wasn't enough weight to affect the driveway at all.
My wife and I were even saying we wouldn't mind it deteriorating a little more.... that much more grip on a 17 degree grade in the winter.
You may be able to make out the one and only hole I'm talking about in the attached picture...
   / Blacktop or Concrete driveway? #12
Looking at purchasing a home in Ohio with a fairly sloped gravel driveway. Would like to get it surfaced, always liked blacktop more, but looking for recommendations, pros/cons for either....
thanks in advance!
As others have said, proper prep work is the key to having a long lasting driveway regardless of it being concrete, asphalt, or crushed rock.
You didn't say how long and wide the driveway is or how steep the slope is.
I like asphalt for its lower initial cost, concrete for its looks and durability, and when I resurface our ~4,000 square foot driveway this year it will be with crushed rock or recycled concrete. The reason for my surface choice is cost savings, I can do it myself, easier to repair, and I don't have to worry about our expansive soils and freeze/thaw cycles wrecking it. My other gripe with asphalt is tracking oil/tar into the garage/house.
Get some estimates for asphalt and concrete, see how much sticker shock it is for your budget, then maybe reconsider crushed rock.
   / Blacktop or Concrete driveway? #13
My drive is one continuous slope and is made of asphalt. After 20 years, cracks are starting to show. I really do like the way the snow melts quickly.:)
With both asphalt and concrete, the base is very very important.
   / Blacktop or Concrete driveway? #14
A quality concrete drive is far superior to a quality blacktop drive. The reason for sealing blacktop is to keep water from penetrating it. It doesn't need to be done every year. Maybe every 5-6 years. Some people just like the looks of a freshly sealed drive. The reasons you don't see streets being sealcoated is because the base is almost always better than what a guy blacktopping a drive will do, and blacktop streets nearly always have better drainage than driveways. It's been many years since I compared price between concrete and asphalt but a concrete drive used to run about 2 1/2 times what a blacktop drive would run.
   / Blacktop or Concrete driveway? #15
:thumbsup::thumbsup:
Check the prices and the budget and go with concrete if it's affordable.
Asphalt starts deteriorating the day it's installed.
   / Blacktop or Concrete driveway? #17
I've had black top on my 1,200 ft. road for 24 yrs. now ..we sealed in after the first 6 mos. and then again after 10 yrs. the road is boardered by bermuda grass pastures so once a year we spray roundup along the edge of the road to keep the bermuda grass at bay. The road has held up great and we had a real good base before we put it down.. You do not need to sealcoat it ever if you have a good installation to start with and seal it 6 mos. after it has been down. If you are going to jack something up on it..put a board under your jack..problem solved. Concrete cracks and you can have a real mess but with black top you can always top it with one inch and your road is totally resurfaced and not expensively.
   / Blacktop or Concrete driveway? #18
There was a thread last winter of a guy that had a long concrete drive with some steep grade, he was parking at the bottom and walking up with ice shoes cause his driveway froze and he couldn't or wouldn't put sand/salt on it.
Around here in New England you will not find many concrete drives, their OK for down South but not where the ground heaves 4 inches or more in the winter. There were some areas of my driveway that looked like a roller coaster this year, but they are going back down.
Freezing and thawing is brutal on concrete, even with a Govt project base and heavy steel reinforcement, where the structure is not compromised, there's not much that's looks worse than a concrete surface all spalled and chipped.
JB.
   / Blacktop or Concrete driveway? #19
I put myself through college (and with the help of the G.I. Bill) working for an asphalt paving and grading company and I worked on anything from freeway projects to parking lots. The key to a residential asphalt driveway that is well prepared base-wise is to add a border of at least P.T. 2x material or ideally a concrete berm (curb) to contain the asphalt then backfill and tamp the border.
   / Blacktop or Concrete driveway? #20
If you can afford it, concrete. It your drive is long or on the north side slope, blacktop.
VOLVO QUICK COUPLER MAST W/ 72" FORKS (A52705)
VOLVO QUICK...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2015 VOLVO VNL64T TANDEM AXLE MID ROOF SLEEPER TRUCK (A54313)
2015 VOLVO VNL64T...
2015 FREIGHTLINER CASCADIA DAYCAB (A53843)
2015 FREIGHTLINER...
2014 Volkswagen Passat Sedan (A53117)
2014 Volkswagen...
2005 CATERPILLAR 730 OFF ROAD WATER TRUCK (A51406)
2005 CATERPILLAR...
