Blocking the clutch on a 4400
   / Blocking the clutch on a 4400 #1
RoyJackson
Rest in Peace
Bethel, Vermont
John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
Hope one of you 4200, 4300 or 4400 owners with a gear transmission can help me here...
My old 790 had a tab (on the floor plate) I could clamp the clutch pedal to when the tractor sat for an extended period.
Haven't found anything like this on the 4400 (yet). Is there something similar, or am I going to need a block of wood (or something similar)?
   / Blocking the clutch on a 4400 #2
There should be no need to block pedal down on 4400. It has a wet clutch where the 790 had a dry clutch. The dry clutches tended to absorb moisture and rust to the flywheel when not used for extended periods. For that reason deere did not provide a way to hold pedal down on 4000 series.
Good point!
I'd forgotten about this being a wet clutch.
2005 Chevrolet C4500 Altec Bucket Truck (A50323)
2005 Chevrolet...
New/Unused 20ft Farm Iron Gate (A48837)
New/Unused 20ft...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A51222)
2015 KENWORTH T370...
1984 Trailmobile Enclosed Van Trailer (A51039)
1984 Trailmobile...
2021 McFarlane IC-5140 Vertical Tillage Tool (A50657)
2021 McFarlane...
