Rod in Forfar
Platinum Member
- Joined
- Apr 10, 2010
- Messages
- 575
- Location
- Forfar, Ontario, Canada
- Tractor
- 1960 Massey Ferguson 35 (Perkins), 1995 TAFE 35DI, 1980 Bolens G174, 2005 Kubota B7510, 2020 Kioti Mechron 2200ps UTV Troy-Bilt Horse 2 1988 Case IH 255 4WD with loader and cab
Ever since I removed the float bowl to clean the filter, the thing has leaked a bit. Then it drained the tank and my neighbour ran it dry, so off it came again. I tightened it carefully with a channel lock wrench. No go. Last night I assembled the thing and tightened it gently against the O ring. It leaked about a litre overnight.
Bleeding the fuel system after every attempt to fix it makes me reluctant to deal with this. It seems diesel leaks are a bit beyond my level of mechanical competence, but I wonder if there is a cracked part somewhere above the filter bowl.
How do I fix it?
Does anyone have a good supplier of replacement tires for this tractor? Fronts are Bridgestone 6-12 diamond pattern and the rears are 8-16's.
How do I fix it?
