Item Details
- Auction ID
- 55315
- Make
- Boss
- Type
- Lawn & Garden Equip
- Year
- 2026
- Auction House
- Fastline Auction, LLC
- Location
- Texas
Description: Keep your operation running smoothly with the BOSS MT 660 Fuel Trailer, a rugged and DOT-compliant mobile refueling solution designed for farms, ranches, and construction sites. Built to safely transport and dispense diesel fuel, this trailer helps reduce downtime by bringing fuel directly to your equipment in the field. Key Features: 660-gallon diesel fuel capacity DOT-approved mobile trailer for on-road use Heavy-duty steel tank construction for durability Electric pump with hose and nozzle for easy dispensing Tandem-axle design with brakes for stability and safety Lockable cabinet for secure storage of fuel accessories Designed for agricultural, industrial, and construction applications The BOSS MT 660 is engineered for efficiency, reliability, and convenience-perfect for operators who need a safe and cost-effective way to refuel tractors, trucks, and heavy equipment on-site. 12,000 lbs G.V.W.R. 2-7,000 lbs. Dexter Elec. Nev-R-Adjust Brake Axles 6 110 Gal. Smooth Plate Tanks 3/16IN Thick Smooth Plate Side Walls, 10 ga. Smooth Plate End Caps, Floor and Top Slipper Spring Suspension 16IN Black Mod 8 Hole Wheels ST235/80R16 14 Ply Radial Tires 8IN Channel Frame & Tongue w/28 Extension Ready for DEF 2-5/16IN Adj. Demco 2 Bolt (21K) Cast Coupler 1-10K Spring Loaded Bolt-On Jack Double Broke Heavy Duty Fenders Large Front Tongue Tool Cabinet (2 Doors On Each Side) 1IN Fitting Underneath Center of Tank Bottom With Swirl Basket 1IN Manual Valve Underneath Each Tank Heavy Duty At-A-Glance Fuel Gauge On Top Of Each Tank 2 2IN Fill Ports On Top Of Tank, 1 on Driver Side With Ventable Cap, 1 on Passenger Side With Plug Manifold with 1IN Manual Valves for Each Tank Full Insulated Wiring Harness w/7 Way RV Plug-In Flush Mount Led Lights Sherwin-Williams Zinc Epoxy Primer w/Powdura Polyester Top Coat Powder Coating FASTLINE SALES REPRESENTATIVE(s) Toni Haste toni.haste@fastline.com 817-319-0247 Bobby Kennerson bobby.kennerson@fastline.com 337-255-0637 Item Location - Address: Provided by Seller Item Location - City: San Angelo Item Location - State: Texas Item Location - Postal/Zip Code: 76903 Item Location - Country: United States
This is a online bidding auction by Fastline Auction, LLC
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved
see lot description, multiple locations, KY 40010
Starting Bid: 10000.00 USD
Auction Finishes: November 18, 2025 at 06:22 PM
Click Here To Bid Now!
Happy Bidding!
Happy Bidding!
