In did a review some years ago with my
BX2660 and
B3200 sitting side by side. BPfick went from a BX to a B and back to a BX and also did a great comparison report.
I also mow a hillside with some fairly steep sections which is why I have the F3080 4wd for owing at home and use a F2680e 2wd for my flat rental property.
I started with a
BX2200 FEL MMM and due to needing more ground clearance and a bit more traction traded to a
B7800 FEL and Rear Finish Mower which I kept for 3 years (Till paid off)
). I also bought a
BX1500 MMM for mowing during those 3 years. The
BX1500 was the most stable hillside mower I owned prior to the F model mowers. The
BX1500 MMM ended up in W Va from Barlows and sure it's still over there on that steep hillside. I traded the
B7800 to a Grand
L3240 HST and it scared me almost out of the tractor business due to how high my butt was off the ground. Got rid of it quick, under 100 hours. The L had great traction at twice the weight but I wanted closer to the ground more than great traction.
The BH on the back with either model throws off the center of gravity and it can be felt on every hill side but the BH is fairly easy to remove and put back on so can be used just for BH work for those of us on hillsides. I never did take it off but have owned the F mowers for mowing so wasn't that big of an issue for me.
The higher off the ground the scarier it is even by inches on hillsides that can't be traversed by going up and down, in my opinion.
The back hoe bucket can be stretched out and kept low on the ground on the high side of a hill and be fairly safe if one can be aware of where it is running in relation to stuff that it might hit for that rare need to cross a hill.
Kubota has reduced interest, not 0% but reduced interest for used Kubotas bought from a Kubota dealer.
I also prefer the RFM on tractors as long as I have a small mower to do the around the house and close areas. The RFM is less expensive to buy but much easier to install and service plus will add so low down stability for a B model.
Troy: The
B2320 FEL BH that Barlows has with around 100 hours wasn't my trade in. It's one he has or had on his lot last week and it is HST. I had a
B2320 a couple years ago, my first and last ever gear drive tractor.
You need to stop by my house again and take the RTV thru the woods.
I'll let you mow my yard on the F also and won't charge you.
Chucky: Just call Barlows and ask how he'll trade and if your payments are in the range you feel OK with, then go for it on the B and he may have other
BX25's for you. If you've paid $2000 so far for 50 hours of use then it's cost you $40 an hour for using your tractor which is fairly cheap plus fuel which is usually a gallon per hour. Still not bad and you've learned a lot about buying the next "RIGHT" tractor and education isn't usually free. Why not enjoy your tractoring hours with a machine you'll be happy with and it will have just cost you a small bit of money which you can make up for on the "RIGHT" tractor. See how easy I have been to talk myself in to trading tractors......It's to make ME HAPPY and I'm to old to worry about the cost of my education vs happiness. TROY: Knows what I'm talking about....He does it to.
