Box Scraper Box Blades
   / Box Blades #1
NYBOB
Maine NY(Binghamton area)
2007 JD 3720
I started looking at 6 foot box blades. My dealer has Landpride but they are over $800. Is there a good but less expensive brand I should look at? I would be using it to level areas on my property and also stones in my driveway.
   / Box Blades #2
Which Landpride? I think they make light, medium and heavy duty units. The heavier duty models are more expensive and might be more than you need.
The best thing to do is to look at the specs on different units. Look at how heavy it is, how thick the side plates are, look at how it connects to the lower links (captured pins are much better). Once you've decided which models will fit your needs, shop around for them.
I ended up with a Bush Hog BB720. Bush Hog considers it a light duty model but it is heavier and uses thicker steel than most of the KK, Howse, etc brands that you see at places like TSC. A KK or Howse might suit your needs perfectly but I wanted something a little beefier. The Bush Hog that I bought had been sitting on the lot a while and I got it for around $650 (I'm a bargain hunter). I use a 4wd 45hp tractor and I've done some pretty significant earth moving, I've hit a lot of buried stumps and rocks and I've done a good bit of pushing in reverse and it has held up well. Nothing bent, no broken scarifiers. JD, Landpride and several others make boxes with very similar specs that would do just as well or better. Shop for the best price.
Also, some BBs come with a hinged rear plate. This adds considerably to the price so decide if you need that feature or not. I didn't need it.
   / Box Blades #5
Rear hinged makes it dig in faster and deeper without tipping it forward as much for a smoother cut.
jb
   / Box Blades #6
Any recommendation on the ones that AG store offers?
ASC # 10366 Box Blade **Freight Included
or this one
ASC # 10367 Box Blade **Freight Included
My tractor is only a five foot wide. So I think the 6 foot would be best. Any ideas on the choice between the 6 or 7 foot would be appreciated too.
I'm considering one also. Didn't think id ever have a use for one. but I am thinking that one would come in handy.
Some weigh about 500 lbs, and would make a good weight box,for added removable weight I had an idea that I could make a concrete poured block that would fit down in between the boxsides and front with some sort of way to attach it inside.Possibly on the bar that holds the 'teeth' for added weight.This would make it removable when using it for scraping.
The idea is that I could back over the concrete, and lower the box down over it.
Ive searched here box blades, without much success, am I using the wrong wording ?
Thanks Allan.
   / Box Blades #7
NYBOB - You have probably noticed that one of the main parameters mentioned often for the box blades/scrapers is the weight. The lighter it is the more likely it is to bounce over harder areas or small rocks. I bought the heavy duty Gannon distributed through Woods which is ~1200 lbs to avoid the bounce. You mention stones on your driveway are these small(~3/4") and used for a top layer. If so an inexpensive 3pt hitch rake may be the ticket for that. application.
   / Box Blades #8
jb
John
I have a 8' LandPride with a rear hinged blade. The blade on mine does nothing when you are pulling the box forward. It simply floats out of the way on the hinges. It allows the blade to drop down when you use the box pushing backwards like a plow. Landpride calls it a "Backfill Blade"
Andy
2011 JCB 541-70 TELESCOPIC FORKLIFT (A51242)
2011 JCB 541-70...
2000 Trinity Built Trailer (A50514)
2000 Trinity Built...
2015 Cadillac Escalade ESV Platinum AWD SUV (A50324)
2015 Cadillac...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR89J160632 (A51572)
2009 International...
2015 Dodge Charger (A50324)
2015 Dodge Charger...
CAT 573 FELLER BUNCHER (A51242)
CAT 573 FELLER...
