Box Scraper size??
   / Box Scraper size?? #1
Bob_S
Bronze Member
Central Ma
JD 4310 hydro, 4wd
Can anyone suggest which size (60" or 65") box scraper to purchase for my just slightly less than 5 foot tractor width. I am surprised that these two sizes are both available being only 5 inches apart. I am thinking that subtle differences are somehow necessary or at least desirable so I don't want to make the wrong decision. /forums/images/graemlins/blush.gif Thanks for any thoughts.
   / Box Scraper size?? #2
I suggest that you get one that is slightly wider than your loader bucket, or rear tires, whichever is wider.
If you have a high HP/weight tractor maybe going even wider might work fine. If you don't do heavy digging with the box blade maybe going wider will be fine.
My experience tells me that I would not want a box blade that was narrower than my loader bucket, because there have been times when I scraped with the box, and then followed it with the loader bucket while scraping more with the box at the same time.
In MY mind, a good match is keeping the loader bucket and box blade both wider than the tractor tires. How much wider depends on the tractor and how much power it has.
Edit: I also think I would want the box to be equal or wider in width to the loader bucket. That way the loader could run down a slot cut by the box blade...a box blade narrower than the loader would not be as useful in my opinion. I can't say experience, since I have a 54" loader bucket and a 60" box blade...
   / Box Scraper size?? #3
If your tractor is 60" wide, I'd go with a 72" box. The reason being is that only 5" is very close for when you need to get up close to building, or say, a driveway and remove dirt.
I made the mistake of buying a box that was just about the same width as my rear tires. Now, when I need to go parallel to a building, I have to swing the tractor so that the box goes up near the building, and do that several times in order to remove the soil. With a 72" box, you'd have enough sticking out on each side that you could easily get your tractor and box moving along whatever stucture you're working with.
I would imagine that if your tractor is 5 feet wide, it will easily handle a 6' box. With anything smaller, I'm not sure you would have a comfortable clearance of the tractor in a situation such as I describe.
John
2022 Chevrolet Tahoe SUV (A48082)
2022 Chevrolet...
2008 CATERPILLAR 320D L (A50854)
2008 CATERPILLAR...
UNUSED Brown Metal Roof Wall Panels (A50860)
UNUSED Brown Metal...
Club Car Electric Golf Cart (A48082)
Club Car Electric...
Tubing A500 Grade C 6in. SQ x 1/4in. x 28ft. (A50860)
Tubing A500 Grade...
2004 Ford F-250 4x4 Crew Cab Mechanic Service Truck (A49461)
2004 Ford F-250...
