Boxblade Usefulness Survey
   / Boxblade Usefulness Survey #133
Box blades have a purpose, but for keeping long drives or roads smooth a wheeled scraper id the way to go.
With a box blade it moved up and down as the tractor moved up and down hitting ruts. With a wheeled blade it stays on it's own level track regardless of what the tractor does.
I was using a box blade only, but had way too many waves, put on a wheeled scraper and it's as smooth as glass.
   / Boxblade Usefulness Survey #134
I'm using BB somewhat atypically, I guess. I'm establishing food plots for deer in NE PA. Soil is too rocky to plow and hard to disc before it's broken up. Had been using spring tine harrow very effectively, but it dug too deep and pulled up more rocks with every pass. Don't have draft control, unfortunately. That would probably help. I found that if I use the HTL to get both blades of the BB to skim the surface without much digging, the scarifiers go down several inches to rip up the soil and loosen up rocks on the surface. This does not tend to bring deeper rocks to the top like the STH tends to do. It also helps to herd rocks into short rows, making scooping with stone bucket easier.
   / Boxblade Usefulness Survey #135
   / Boxblade Usefulness Survey #136
Spiveyman said:
... I've been doing research on what to buy and have one picked out...
So, what are ya gonna get Spivey?
   / Boxblade Usefulness Survey #137
He already bought one. IN a thread here.
jb
   / Boxblade Usefulness Survey #139
PaulChristenson said:
Instead of a box blade...this is what he should of bought...:D
The Absolute Innovations line of Arena Drags: Featuring the TR3 Rake!
"We the members of TBN do solemnly swear to at all times commit to helping our fellow bretheren spend all of their hard eared money in the acquisition of tractors and/or tractor attachments, upgrade equipment as needed, and actively defend their/our right to do so" :D Jay
This could be in the TBN "Charter" :)
   / Boxblade Usefulness Survey #140
I bought my six foot Land Pride box blade because I was told how handy it was. The one implement that you cannot live without.
I spent dozens of hours using it, and the more I used it, the more I realized that for every job I used it for, I had something that would do the same thing, but better.
I don't believe in dragging and smoothing a gravle road with a box blade. All that does is thin out the rock and ruin the road. If you have a low spot, fill it in with new rock. Never cut down the good rock down to the lower level.
If you want to smooth dirt, then a drag is much smoother and easier.
For digging ditches or dirt, just about anything is better.
For breaking hard packed clay, I found it's actually faster to use my disks on the ground without breaking it up with the scarfacers. Granted, the scarfacers will break up the ground, but the amount of time it takes to change implements and then break up the ground with them, then change over the disk to finish it off isn't any faster then just putting on the disk and doing it all with that.
My brother will be moving out here sometime in the future and will be buying a tractor. I'm gonna give him my box blade as it's been sitting for three years and is just yard art.
Eddie
2012 International ProStar T/A Day Cab Truck Tractor (A56858)
2012 International...
2015 DRAGON 130BBL VACUUM TRAILER (A58214)
2015 DRAGON 130BBL...
2014 Freightliner M2 106 5.1Yds Asphalt Pot Hole Patcher Truck (A56858)
2014 Freightliner...
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2013 Chevrolet...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2016 WINNEBAGO SCORPION 4014 5TH WHEEL CAMPER (A58214)
2016 WINNEBAGO...
