Spanner
Veteran Member
Looking forward to a resolution.
Wishing you a full recovery from your fall.
I have read about shaft seal leaking on a pump allowing hydraulic oil into the engine but don’t think have ever heard of engine oil going into hydraulic reservoir via the pump.That is one of my concerns. Some experienced tractor mechanics on this forum may know the relationship between the hydraulic pump and the engine oil but it is not clear to me. One of the service people I talked to said there is a seal, if broken, that can allow the migration of engine oil into the hydraulic oil reservoir.
The more I think about it, as quickly as the engine oil was disappearing with no leaks it seems logical that engine oil was moving into the hydraulic system. If the tractor was burning engine oil I don't believe the engine would have burned over a gallon of oil in 20 minutes of running at low RPM.
Sounds like a possible scenario. I hobbled up to the shop checked the oil, started the engine up, and let it idle for about 30 minutes. Everything sounded good and the oil level didn't change after shut down.I have read about shaft seal leaking on a pump allowing hydraulic oil into the engine but don’t think have ever heard of engine oil going into hydraulic reservoir via the pump.
It might be possible if shaft seal is submerged in engine oil and shaft seal area is connected to pump inlet and inlet was under vacuum pulling oil from engine to hydraulics.
I've broken a rib, two times, both bicycle crashes. I can attest to feeling less uncomfortable wheezing around doing something rather than trying to set. Never broke multiple at once though.Sounds like a possible scenario. I hobbled up to the shop checked the oil, started the engine up, and let it idle for about 30 minutes. Everything sounded good and the oil level didn't change after shut down.
My wife thinks I'm crazy but I feel better standing up rather than sitting. If nothing else it made me feel better just doing something however small.
I agree. Engine oil is pressurized unless in the pan, OTOH hyd oil is only pressurized leaving the pump.I have read about shaft seal leaking on a pump allowing hydraulic oil into the engine but don’t think have ever heard of engine oil going into hydraulic reservoir via the pump.
Glad you are able to move around.Sounds like a possible scenario. I hobbled up to the shop checked the oil, started the engine up, and let it idle for about 30 minutes. Everything sounded good and the oil level didn't change after shut down.
Keep moving, your body will love you for it and your recovery time should take less time. A lazy body takes a lot more time to fully recover. Plus there is always the chance for Pneumonia from sitting idle too much.Sounds like a possible scenario. I hobbled up to the shop checked the oil, started the engine up, and let it idle for about 30 minutes. Everything sounded good and the oil level didn't change after shut down.
I can't lie down on a bed or tie my shoes but I can walk. Got about a mile and a half in this afternoon. Hope to increase that tomorrow.Keep moving, your body will love you for it and your recovery time should take less time. A lazy body takes a lot more time to fully recover. Plus there is always the chance for Pneumonia from sitting idle too much.
mowpart.com
When they picked up my machine the service guy said the pump was making a lot more whining noise than it should. I have no idea if that was caused by the seal or the pump but like you I'm glad they changed the whole assembly.They could just replace the $15 or $20 shaft seal, instead of changing the entire pump, but I guess it's under warranty so it's probably better that way.
Seals probably went out due to another defect in the pump/shaft. Better to just replace it.They could just replace the $15 or $20 shaft seal, instead of changing the entire pump, but I guess it's under warranty so it's probably better that way.
It probably pulling air mixed with engine oil from the shaft seal being bad. This causes cavitation and makes that whining noise.When they picked up my machine the service guy said the pump was making a lot more whining noise than it should. I have no idea if that was caused by the seal or the pump but like you I'm glad they changed the whole assembly.
Possibly, but I'm leaning more towards that the seal may have got damaged during assembly of the pump, considering it happened at very low hours.Seals probably went out due to another defect in the pump/shaft. Better to just replace it.
A little bit more at a time and you will be like new in no time at all. I have had 12 surgeries so far.I can't lie down on a bed or tie my shoes but I can walk. Got about a mile and a half in this afternoon. Hope to increase that tomorrow.
The best part is that your tractor is fixed now. Hopefully it stays that way.Received the information about what work was done on my tractor:
Hydraulic Pump, Gear
Several O-Rings
Oil Pressure Filter
HST Filter
Hydraulic Fluid
I'm not sure where the hydraulic pump is located on this tractor but the dealer only listed 1 job hour for pump so I'm sure it is not an internal component.
I hope this completely corrects the issues. I'm anxious to work the tractor some to check everything out.
