brand new tractor ...need help
   / brand new tractor ...need help #1
yukonhunter
leroy ny
John deere 5100m, mf1643 cab and kubota bx2370woods bb720x land pride disc and reverse tiller
I have a brand new jd 4520 sitting in my pole barn...its been a terribly cold winter and I haven't started it since November...I went to start it this weekend and it made a fast clicking sound when trying to start it...any ideas what it is...dying battery??? Thx guys
   / brand new tractor ...need help #2
Fast clicking sound could be a battery in need of a charge, especially if it's been sitting all winter.
   / brand new tractor ...need help #3
I'm with Happy... sounds like the starter relay clicking due to low voltage.
I keep a trickle charger on my vehicles that don't get used for months over the winter.
Pete
   / brand new tractor ...need help #4
Fast clicking is almost always a dead battery. A battery maintainer is a really good idea if you're going to let it sit for long periods of time (the battery will last a lot longer that way), and the good thing is, they're inexpensive.
   / brand new tractor ...need help #5
Battery needs recharging. If you don't plan to use the tractor during the cold months, remove the battery, charge it up fully and put it on a trickle charger.
   / brand new tractor ...need help #6
Your in N.Y. where I am, been below zero many times out in the country. Buy a Battery Tender, it will maintain the charge and never over charge like trickle chargers will. I have 4 , motorcycle , Kubota, Truck, Small lawn tractor, and have used them for years. About $50.00 @ Wallys.
DevilDog
   / brand new tractor ...need help #7
Fast click is the starter relay.
Modern electronics do not like low / variable voltage. Sure fire way to cause expensive failures is to let the battery fail.
If you do get a trickle charger, get a good one. The cheap ones can actually damage the battery by continuously putting too much juice in after it's fully charged. The above post on a battery tender is good advice!
   / brand new tractor ...need help #8
   / brand new tractor ...need help #9
I used to have this issue for many of my engines, big or small. Part of my problem was how I moved the equipment around before storing it. I was starting something, moving it out of the way, shutting it down within a couple minutes and then leaving it sit for weeks. The batteries weren't charged properly before storing because of that, so they sulfated and wouldn't hold a full charge. Leaving a battery sit for weeks drains them too. Now I use battery minders on everything at least once a month, if not on continuously. My batteries are holding a charge like new again.
Thx so much guys....I'm going to buy one today...I feel better now lol
2018 Ford Escape (A50324)
2018 Ford Escape...
2018 ISUZU FTR 24FT BOX TRUCK (A51222)
2018 ISUZU FTR...
Agro Trend 7' 3PT Snow Blower (A52349)
Agro Trend 7' 3PT...
1995 OTTAWA SPOT TRUCK (A50459)
1995 OTTAWA SPOT...
UNUSED CFG INDUSTRIAL SSFM81 FORESTRY DRUM MULCHER (A51244)
UNUSED CFG...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
