brand new tractor ...need help
   / brand new tractor ...need help #12
naaa, i think the tractor appreciates staying indoors all winter.....and doesnt want to work anymore.
its cold out there
   / brand new tractor ...need help #13
Did you get her to start up ok?
   / brand new tractor ...need help #14
How'd you make out yukonhunter?
I'm going to my cabin in the morning ...I bought a jump charger...called the dealer...he told me to take it out and if its bad that they will replace it....do you think it is a bad battery dying after only two months of sitting???
   / brand new tractor ...need help #16
I remember reading/hearing somewhere that a fully charged battery is only at 50% at zero degrees. It is very possible that it died after a few months. Most SCUTs don't have an alternator so the battery takes a bit to be fully charged using the dyno.
   / brand new tractor ...need help #17
According to parts catalog a JD 4520 has an alternator. Can you name some SCUT's with a dynamo? I thought all late model tractors had an alternator but so much for old folks thinking.
   / brand new tractor ...need help #18
sounds like you need to charge your battery real good.an then if your going to let it set for long periods of time crank it once or twice a week.or put a trickle charger on it every so often.
   / brand new tractor ...need help #19
Kubota B series ... my buddies B2920 had one.
   / brand new tractor ...need help #20
Unless you left something on, the battery shouldn't have gone dead in 2 months, even in cold weather, I parked my old f600 for a year and a half, the battery was 3 years old when parked, it started on its own with no jump, I did have to dribble a little gas down the carb.
Take the dealer up on his offer, return the battery for a free replacement.
I use these on my Tractor, Boat, and riding mower. I bought the three pack 3 years ago, they work great, they keep the battery fully charged without overcharging,
1 pack http://www.amazon.com/Battery-Tender-021-0123-Junior-Charger/dp/B000CITK8S/ref=sr_1_1/191-4492021-5054432?ie=UTF8&qid=1395525841&sr=8-1&keywords=battery+tenders
3 pack Amazon.com: 3 PACK Battery Tender Junior Jr. 12V Battery Trickle Charger 12 Volt: Home Improvement
2019 PETERBILT 579 DAYCAB (A58214)
2019 PETERBILT 579...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
Set of Heavy Duty Steel Trailer Ramps, 60" Long (A59076)
Set of Heavy Duty...
2020 Case CX80C Excavator (A59814)
2020 Case CX80C...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
