Broke down an bought a new Chevy
   / Broke down an bought a new Chevy
Well the tag on the tru say 1800 tong wt 17,000 lb tow capacity I'm going through the manual now but the front axle is 6,000 from 2010 on after the chassis redesign
   / Broke down an bought a new Chevy #43
Well at any rate it is immaterial anyway because I will not be towing anything close to that anyway. It is to late out here tonight and I'm not going out again. Besides I have all the tractor trailers I need at my disposal anyway. It's what I do for a living. I kind of figured a long time ago that I'm not sure about anything anyway.
   / Broke down an bought a new Chevy #45
From what I just read on the GM web site the 2500 series has a 4,400# front axle, not the 6,000# axle. The 3500 series trucks have the 6,000# front axle.
I just hope the dealer did not feed you a bunch of bad info. I see it all the time. I am a part time trailer dealer and it happens weekly when I have someone come by with information that is not correct.
Did not know you were a trucker. You know all about axle ratings, GVWR, GCWR, ect. Sorry for going so in depth earlier. Most people I deal with selling boat trailers and utility trailes have no clue.
Good luck with the new truck.
Chris
No apology required Chris. I have been Managment for years now, though I still jump in a rig any chance I get. Being a trailer dealer you probably touch closer to this than I do. I know how to axle a rig at 80,000 with sliding tandems and 5th wheels but you might be better with my pickup
   / Broke down an bought a new Chevy #47
Yea, you lost me with all that big rig talk.:D I have some boats moved time to time by semi but I leave it up to the professionals like you.
Chris
Just to follow up this is the door tag
Hitch tag
Slide in camper tag
Things are what they are
   / Broke down an bought a new Chevy #49
I understand the hitch is rated at that but the truck is not. Its a common misconception. They use that hitch on many applications.
The GM web site is wrong on some info that I have gathered such as the front axle GVWR.
In your owners manual it will have a chart showing your tow rating based off your engine, axle, cab, and bed configuration.
Chris
   / Broke down an bought a new Chevy #50
Chris
Timber, follow Chris's advice. I almost got burned following tags and dealer info with a 8.1L Chevy. They kept feeding me 1 ton diesel towing info. According to the owner's manual, the truck had and actual tow cap of almost 3k lbs less. We just want to make sure you tow safely. Door and hitch tags can be deceiving.
2020 PRAT TL (A55758)
2017 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
2012 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A58017)
2012 FREIGHTLINER...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
2012 FORD F-250 SUPER DUTY (A58214)
2012 FORD F-250...
