Broken gc1720 transmission filter
   / Broken gc1720 transmission filter #31
At least it's behind you now.
It's certainly not good news for future victims of this kind of accident.
   / Broken gc1720 transmission filter #32
I just broke the fluid filter off today on my Massey GC2300.. at first I accepted the fact that I'll have to replace the front cover to the transmission..but after some research I have discovered this pipe nipple fix! I am going to look into this further. If I can cut the existing nipple off flush and tap for the new Kubota nipple part: 15241-32290.. I hope this avenue works for me... If anyone with a GC2300 could chime in and let me know how this fix went for them?
   / Broken gc1720 transmission filter #33
Yes our rescue kit will work for you.
It comes with the adapter you need to install, and the correct drill bit/tap to make the repair.
This Kit retains the use of the same Transmission Filter that is recommended by Massey Ferguson.
If you have a factory U bracket that goes under the filter, we have a Sentinel protector for you.
In not we will provide just the rescue kit.
   / Broken gc1720 transmission filter #35
You guys are my hero's. Will be getting this ASAP! Snow should be flying soon here in northern BC..
   / Broken gc1720 transmission filter #36
My only last question is what do you guys recommended using to cut off the existing nipple with? I was thinking my angle grinder with a cut off disk? Anything out there that's better? More precise? Im feeling relief about this option but I am also a little nervous about cutting and then making sure I get the drill square before tapping for new threads.
   / Broken gc1720 transmission filter #37
I sent you a PM with the install instructions.
   / Broken gc1720 transmission filter #38
I lost the link to sentinel page can you post it?
   / Broken gc1720 transmission filter #40
thank you
2018 KUBOTA SVL75-2 SKID STEER (A52707)
2018 KUBOTA...
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A56129)
2016 INTERNATIONAL...
GE DEEP RINSE WASHING MACHINE (A57192)
GE DEEP RINSE...
(APPROX 40) 1 1/2" X 1 1/2" X 74" TUBING (A57192)
(APPROX 40) 1 1/2"...
25 TANDEM DUAL GOOSENECK TRAILER (A58214)
25 TANDEM DUAL...
2014 Chrysler 300C Sedan (A55853)
2014 Chrysler 300C...
