Bush Hog RZ760 for CK30
   / Bush Hog RZ760 for CK30 #1
jpierce
Bronze Member
NE Kansas
Anybody have experience using one?? I am deciding to buy a new tractor or not and this is available locally (used) for $500.
Any thoughts or recommendations on using this?? Ck30 should be enough tractor to use this without trouble, correct??
Thanks for your time!! I have been shopping for several months now and getting close to a purchase!!
   / Bush Hog RZ760 for CK30 #2
I don't think you'll have any problem running that mower. If you get into something a little too high, just take a lessor bite. After you have control of it, you shouldn't have to partial cut again. Price is good. Just make sure the spindle is tight, well lubed, nothing too bent or bolts loose. Check for crack lines etc. Right where the gear box goes into the mower, make sure there are no cracks from underneath around the bolts. John
Agco S150 Manure Spreader (A50774)
Agco S150 Manure...
2016 Ford Fusion Hybrid Sedan (A50324)
2016 Ford Fusion...
LONG 445 TRACTOR (A51243)
LONG 445 TRACTOR...
UNUSED AGT QUICK ATTACH FLAIL MOWER (A51244)
UNUSED AGT QUICK...
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
John Deere 702 Hay Rake (A50515)
John Deere 702 Hay...
