Bush Hog SQ840
   / Bush Hog SQ840 #1
dlauffenburger
Warren PA
JD 5425 w/542 Loader
I have been looking for a 7' 3PT rotary cutter and a dealer told me, on the phone, that he has a used Bush Hog SQ840. He stated that it is only a couple of years old and that it is a heavy duty unit.
I have been unable to find any specs for this unit on the net, not even the Bush Hog site, but from a couple of old posts on other forums it looks like this unit is not highly rated and is a light weight unit.
Can anyone give me some insight into the Bush Hog SQ840.
Are the Bush Hog units reliable?
Any info is appreciated before i drive an hour to see this unit.
Thanks again,
Dave
   / Bush Hog SQ840 #2
I have a Bush Hog SQ 480 (48") and a 285 (5'). Bush Hog calls the 480 light duty and the 285 medium duty. The SQ is actually mounted on the FEL of a 45hp tractor and hydraulically driven so that it can be raised up and dropped into 3-4" trees. Over the past 10 years I have broken several blades and bent the housing up pretty bad. But the gear box seems to be holding out just fine.
   / Bush Hog SQ840 #4
Directly out of my Squealer Operator's Manual:
SQ-840
L=120"
W=88-1/2"
Cutting width=84"
Weight (est)=925lbs
Type hitch=Cat.2
Gearbox hp=90
Blades=1/2"x4"
Shear bolt size=Slip clutch
Recommended tractor hp=50-85
Sounds pretty heavy duty to me. It weighs more than twice as much as my SQ-480
NOTE: The SQ-84T is the lightweight Cat.1 model at 720lbs with the same cutting width as the SQ-840 but recommended only for 25-50 hp tractors.
   / Bush Hog SQ840
Gentlemen,
Thanks for the info. From your resposes I will have to go take a look at the cutter, it is advertised for 1600 which is about half what a John Deere model MX costs.
Thanks again,
Dave
   / Bush Hog SQ840 #6
the only thing i dont like about the sq series cutter is the Egg shaped stump jumper, the one i use is so bent up i somtimes rubs the top deck of the cutter. the full circle stump jumper maintaine their shape a lot better.
RIMS AND TIRES (A50854)
RIMS AND TIRES...
2008 FORD F-450 (A50854)
2008 FORD F-450...
GENERATOR HOUSE POWERED BY TWIN (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
2017 Chevrolet Silverado 2500HD Crew Cab Pickup Truck (A49461)
2017 Chevrolet...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2019 KENWORTH T680...
2025 K1230 UNUSED Knotted Wire Mesh Field Fence (A50860)
2025 K1230 UNUSED...
