Rotary Cutter BushHog SQ720 blades not turning.
   / BushHog SQ720 blades not turning. #11
Forgive my ignorance, how do you check for the shearpin?
The PTO shaft from the tractor to the cutter is attached to the input shaft of the gear box. If the PTO shaft turns and the input shaft of the gear box isn't turning, then you've got a sheared shear pin.
   / BushHog SQ720 blades not turning. #12
Bingo!
OK, found the problem, The unit I have has a slip clutch and it was WAY TOO LOOSE, i could see air between the plates. i tightened everything up and she runs like a champ. Thanks for all the input and advice.
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
2004 Chevrolet Silverado 2500HD Service Truck (A53422)
2004 Chevrolet...
2005 John Deere 310G 4x4 Extendahoe Loader Backhoe (A55851)
2005 John Deere...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A55314)
Midwestern...
