I have the FIMCO/Schaben 55-gallon 3-point sprayer listed in one of the links. I have a love/hate relationship with it. I have no problem with the overall construction of the unit; but it could use more features to make it less of a hassle to use. Of course features cost money.
1. I've made mine quick hitch compatible, which is the biggest modification to date.
2. I set up each boom section to be controlled by an individual ball valve.
3. I added tennis balls hanging from a rope at the end of each boom section to set height.
4. I put a jumper on my PTO "Lawyer Switch" so I could hop on and off the tractor with the PTO running and not worry about the engine being shut off.
5. I put a 100-PSI liquid filled gauge on it in place of the 400-PSI dry gauge that came with it. With all the vibration, the dry gauge is worthless.
6. Cam-Lock quick connections between the pump and fitting were added for convenience.
I wrecked the handgun on the first use when I was backing up, and the hose somehow came undone from the from the hose rack. The hose got caught under the rear tire, and before the hose broke, it wrecked the white plastic tee that the handgun is fed from, bent the hose rack where it's welded to the tubular upright, and bent the handgun barrel. All I needed was a new barrel; but those aren't available...you have to buy the whole gun.
Future modifications include:
1. A cheap Chinese knockoff of a Reelcraft self rewinding hose reel with 50' of hose. Swivel connections will be at the handgun/hose interface so I don't have to do the handgun do-si-do to rewind the handgun hose as I do now. I bought the Northern hose reel for $50 so if the nasty chemicals wreck it, no great loss.
2. Electric valves to control the master and boom section valves. With the quick-hitch adapter, it's a long reach to get to the main shutoff valve. I use a piece of heavy wire to extend the handle a bit. Also, hopping on and off the tractor to turn on or off a boom section got old quick. This will be the expensive modification.
3. Move the filter screen housing outboard where it's easy to see and get to.
4. Put a dump bypass line to make emptying the tank faster when cleaning it out. Currently it has to go through the filter screen which slows the draining process.
All of these sprayer regardless of brand come with plastic pipe fittings to reduce chemical attack; but NPT threads on plastic fittings are evil. The plastic is too slippery to get a good friction fit, and one extra 1/4 turn to many will break the female threaded portion of the fitting very quickly. If you add metal pipe fittings, use brass, stainless steel, or plain unplated steel to minimize the chance of chemicals eating at the galvanizing and getting into the rest of the sprayers machinery. NuFarm's Pro-Deuce weed killer even states very clearly not to use galvanized steel containers for their product.
The Tee-Jet nozzles work A-OK and I have no issues with them.
I like FIMCO for their customer service. Anytime I've called for parts or other information, the telephone is answered by a person instead of an automated phone system.
I got my sprayer and pump from Gempler's, and like FIMCO, they have humans answer the phone.
Bottom line...I should have made my own; but I was in the same boat as Eddie and didn't know enough to construct one.
I'll post pictures once I get my new PC up and running.
