BX 60 MMM Time per Acre
   / BX 60 MMM Time per Acre #21
The owner would be money ahead to rent a bush hog for you to use. The production will be way better. I don’t think you’ll tear up the mower unless you hit hidden objects but I’m guessing it’ll take 2-3 hours per acre. Now 2’ tall thin weeds and 2’ tall thick grass are completely different. If it’s thin stuff you’ll be a lot better off.
I am hoping it’s like the pictures I posted. We will see, if he calls back.
   / BX 60 MMM Time per Acre #24
I cut "lawns" like pictured on occasion with my zero turns. Potential customers almost always describe their lawn as "a little high".
Anyway, I had envisioned something higher and thicker than your photos. Assuming you can leave no stand-ups behind, I still think you are still in the 20 hour ballpark for 10 acres. Maybe 10 hours if you can zoom through once and leave some weeds standing.
I charge a minimum of double my standard rate for an overgrown lawn, sometimes 3x if it's a real mess. Drifting further off topic, I have some seasonal customers that have by request delayed the first cut the season, or stopped service too soon in the fall. They get billed double or more for the high grass, and I either get fired, or they knock that cheap behavior off.
Good luck with the job!
   / BX 60 MMM Time per Acre #25
10 acres with a BX...now that is some serious seat time. It looks like you have been able to cut it successfully...at least a few rows. It will cut so just seat time if you are willing. Split it into 3 days.
I went to look at the job site. Here is the actual property. As you can see, it is all at least two feet tall and some up to four feet. Fairly thick, though the angle of the picture makes it look woolier than it is. You can see dirt when you look straight down.
A friend has a brush hog I can borrow, but I don’t know how well the BX will handle it or if I’ll have to buy a PTO shaft, since his 3pt arms are much longer than mine.
A couple of years ago, I cut brush like this, but it was not as thick. There was a lot more dirt visible, from above and it wasn’t as tall.
   / BX 60 MMM Time per Acre #27
When you have health issues and need the money you will do what you can do with what you've got. I feel your situation big time.
If that one big picture in post # 26 is representative, I say yes you can do it. Far from ideal but you could.
1) If all else fails, walk the land to make sure what objects and debris are there, mark anything TOO bad, and then just go after it slow with the MMM set high. Don't let it bog down and burn belts or do damage. If that happens you lose.
2) Talk to your customer and see what his real expectations are. How short does he want it mowed? How flexible is he? Not good idea to start if you aren't going to satisfy him. By the hour versus price to do the job offer pros and cons.
3) For sure the brush hog is the right tool. Since you can borrow a brush hog, make sure it is 5ft or less. You can run a 5ft hog with your BX in that kind of weeds without too much grief. There are several issues for you with using a hog. First your lift arms may not want to spread wide enough to mount the hog. Cat I vs Cat II ? Second, the driveshaft may be too long and might have to be cut shorter to allow you to hitch (I doubt it.). I assume you have to pull the backhoe or is it off ? Do you have lift arms or have to add them to the BX? If you do not already have lift arms for your BX that almost rules out using the hog for a single job...the arms and lift links kit etc are NOT cheap.
I'm going backwards in this discussion but FIRST, before you even think about other options, check the compatibility of that bush hog. If it can be made to work , do it.
Only if you can't use the hog, go into it slowly with the MMM.
If able to use hog, get someone to help you pull the MMM off before doing the cutting.
[There are so many unknowns here -- what you have and don't have to work with, what help you have, how bad your physical limitations are, etc. Good luck!]
   / BX 60 MMM Time per Acre #28
Wow. I wouldn't try a post #26 field with my bx and mmm on 10 ac. I wouldn't do it with my b and mmm. You need a brush cutter and i'd pin up your mmm unless you have a cover over your hydro fan if you rent a cutter. Maybe the later models have a cover on them, but the fan on my bx is exposed. How about renting a 30+ HP tractor/brush cutter for one day and mowing it? Charge your labor rate + the cost of the rental?
The brush hog I can borrow is Cat 1 and I have the 3pt kit and take the backhoe off pretty regularly. Will the PTO shaft work and will I be able to lift the mower high enough to get in the trailer are the two biggest issues. Then how well can the BX power a 5 footer....
Mine has a small cover, but there still is a possibility of something getting in and hitting the fan. I’m guessing the guy won’t call me as my price will be $650-1,000, possibly more. No way I can rent a tractor and make any money. Like I said earlier, I am sure some fly-by-nighter will come in and do it for less than the cost of fuel.
   / BX 60 MMM Time per Acre #30
Your price isn't that far off, as a per acre charge. I mow two different 10 acres about 3 to 4 times a year and am on the low side of that amount. My price has some variances in it, but the customer usually doesn't care how long it takes, just what it costs. The first time I did one, I did it with a Ford 1100 and 4 foot brush hog. The owner had a very similar tractor with a finish mower, that wouldn't cut it(according to his son). Now I mow it with a 70 hp tractor in a lot less time! Make sure your blades are sharp, as that will lessen the strain on your tractor!
David from jax
Portable Restroom (A54865)
Portable Restroom...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
MCELROY COOL PACK 20 (A55745)
MCELROY COOL PACK...
BOMAG BW213 SMOOTH DRUM ROLLER (A58216)
BOMAG BW213 SMOOTH...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
