jbecker,
Agreed. I'm not sure I understand why fel removal/ mounting is much of an issue. As stated before, I always "kick out" the bottom attachment points 5-10 degrees when dimounting the fel. If the attachments are out at the bottom a little, you just drive in, put a little pressure on the attachments as you actuate the boom down position on the fel valve, and it clicks into place ready to drop onto the bottom pins. Remember that the boom cylinders are connected hydraulically so if you are off a little and catch the attachment thats sticking out with the frame it will just spring back, and the other attachment arm will move forward.If you're that far off, just back up and re-align yourself with the fel. If its just a little out of square, a little push with the tractor will line it up. Shut off, hook up hydraulics, rotate the bucket out to seat the attachments, pop the pins in from the seat, and fold up the legs. On in 3 minutes tops. I probably did it 5 times this past weekend. It works for me! Hope this helps someone.
DaveL
