BX23 (XX?) Light Upgrade
   / BX23 (XX?) Light Upgrade #1
tshep
Richmond, VA
BX23 MLB
OK - My turn/hazard flasher failed.
(I resoldered all the back side stuff - remained failed.)
As you know, it's $100 now.
So, researched VA code, wiring diagram, my use - and decided 'turn signals' were useless on a daylight-travel only tractor.
I also concluded, what are they called, twinker lights, in US market were only there for parts sales.
So,
Twinkers off and into spares, wires taped off nicely.
EF32SS-R attached in place of older 'flasher.
Amazon.com: CEC Industries EF32SS-R Flasher: Automotive
1 thin male spade into connector at Hazard, 1 thicker female spade at flasher (polarity matters, doesn't hurt it).
2 thin male spades into connector at Left and Right, tee-ed to 1 thicker female spade at flasher.
Re-attached hanger bracket, rubber sleeve.
Replaced 1076 style in larger round lights with brighter LEDS.
Amazon messed up the link, but 1076/BA15D search covers it (mine were Jomitop).
I do believe the single lamps now makes more light than both did before, and the flasher works fine with only 2 wires and a minimal load.
$25, should be better for longer!
   / BX23 (XX?) Light Upgrade #2
Yup. Out here in CA. we can get away with just the SMV sign, going around the neighborhood (which, I will have to do coming from the backyard to the front, I'll have about a 1/4 mile of street to run on, when I do any work in front) like the Amish do when they travel public roads.
Pick
   / BX23 (XX?) Light Upgrade #3
To be honest, I've never had occasion to use the turn-indicators on my 4105... that's because, if I'm on a public road, I'll have my 4-way flashers going + an amber 'whoop-whoop' going on top of the ROPS (SMV is also present).
I'm simply observant of traffic/surroundings and use hand signals if/as required.
bad boy zero turn 72 (A56859)
bad boy zero turn...
White Metal Roof Panels (A55758)
White Metal Roof...
LOT: (50) 14 Oz. Tubes of Star Fire Multi-Purpose EP 2 Grease (A59076)
LOT: (50) 14 Oz...
2016 Chevrolet Cruze Limited Sedan (A56859)
2016 Chevrolet...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
2013 Ford Taurus SEL Sedan (A56859)
2013 Ford Taurus...
