BX2350 front tire chain info-homemade
   / BX2350 front tire chain info-homemade #1
PA-Woodchuck
Western Pennsylvania
2008 BX2350 FEL
I have an old set of chains that I would like to cut-up to fit the front of my BX2350 with R4 tires. Could someone measure yours from sidelink to sidelink.
thanks
   / BX2350 front tire chain info-homemade #2
If you can wait until late March when they come off I'd be glad to. Otherwise just measure the width of your tire and add an extra 1.5-2 inches on each side.
   / BX2350 front tire chain info-homemade #3
Those are v-bars from tirechains.com on the stock R4s of my BX2350.
Thanks for the help, gives me something to do this weekend. Lask weekend we had 26inch of snow and another 8 on Wednesday. Do you also use a FEL with the chains on, if so how well does the front chains help out?
   / BX2350 front tire chain info-homemade #5
I have not had a load in the FEL since installing the chains. I just use the back blade for moving snow. When I'm pulling a full blade of this heavy wet stuff, going up the steepest part of my driveway, the tractor just barely starts slipping. I have chains all around but without the fronts, I'm sure I would have to back off a little. Last year, under the same conditions with no chains, I just barely made it up carrying the blade with the diff. locked. Almost had to abort and back down.
Dodge Charger (A56859)
Giyi 46" Mulcher (A53316)
Giyi 46" Mulcher...
2009 FREIGHTLINER CASCADIA (A58214)
2009 FREIGHTLINER...
2012 PETERBILT 367 (A58214)
2012 PETERBILT 367...
TOOTHED BUCKET FOR MINI EXCAVATOR (A58216)
TOOTHED BUCKET FOR...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
