Bx25 hydraulic pressure low after fluid change
   / Bx25 hydraulic pressure low after fluid change #1
Natfuel1
Central, PA
2009 BX25
Hello everyone.. I just finished doing a complete service on my 09 bx25. Changed hyd fluid and filter, cleaned screen and filled back up, used super udt2 fluid... I checked the pressure a couple weeks ago at the white port for fel, it was 1675ish.. I figured i would wait till the service and bump it up after as the BH would be off. Well after I finished the fluid change im only getting about 1100psi at the same port. Am i missing something or did i do something wrong, i know the level is fine and there are no leaks.. Is there possibly air in the system? Do i need to run it for awhile before checked ng it? Any help would be really appreciated thanks
Update.. Just ran tractor for a little while and checked again, back up to the 1650 ish mark. Must've been air in the system.
2007 John Deere 1770NT CCS Planter (A50657)
2007 John Deere...
2019 John Deere 317G Track Loader (A50490)
2019 John Deere...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2012 Ram 3500 Crew Cab 8FT. Flatbed Truck (A48081)
2012 Ram 3500 Crew...
5th Wheel Dolly (A49461)
5th Wheel Dolly...
2018 Bobcat T590 Compact Track Loader Skid Steer (A49346)
2018 Bobcat T590...
