BX25D?
   / BX25D? #1
jadefox
Bronze Member
Rockland, Maine
Kubota BX25D, Case 448
We have a four-acre piece of property with a load of projects waiting to happen (and potentially some more property coming online). We moved in last November and are now embarking on our second year working on the place, and we've decided to make a change when it comes to our tractor. Currently we have an '83 Case 448 with a front blade and mower deck. We pull a trailer behind it for loads of chores. It's been a great machine, but I don't have the knowledge/commitment to keep it in tip-top shape, and we really feel like we would benefit from a FEL and backhoe primarily for landscaping projects. In addition to landscaping projects (e.g., planting trees, moving rocks, mulch & chips, etc.) we have the regular chores, including plowing a driveway and parking area for a home-based business, brush-hogging, tilling, and mowing (although I'm not sure we would want to use this tractor to mow the lawn). We've been researching different sub-compact tractors, and we are feeling pretty close to pulling the trigger on a brand new 2013 BX25D with LA240A loader, model BT602 backhoe with BX6316 thumb, BX2506 3-pt hitch, BX6315 quick attach system for loader, and a BX2767 quick attach loader snow plow. Does anyone here have any advice to offer? We likely need to make a decision by Monday. Thanks in advance!
   / BX25D? #2
Sounds reasonable.
Use it as a mower too if you like. No reason not to. Bx tractors are good mowers too
   / BX25D?
Thanks for the reply. Will the turf tires I'd need to mow cut it for the heavy lifting, though?
   / BX25D? #4
Since you don't plan on mowing (which the BX is a good mower) I would look at a B2620. It has more lift capacity on the loader, 3PH, and backhoe but it a fair amount more.
If you go with the BX it sounds like you are getting it equipped nicely. I would add the LED fender mount and ROPS lights to it.
What kind of tires are you getting?
I would get prices from at least 3 dealers to be sure you are being treated fairly.
   / BX25D?
Thanks! It's not that I'm against mowing with it (and we do have quite a bit of lawn, but to mow, I'm going to want the turf tires, right? But will the turf tires cut it for our other projects?
Thanks for that. Are saying get those through Kubota or after market?
That depends I suppose on if we're planning to mow with it, correct?
Good call. I have not shopped the rig around with other dealers. My quote is around $22K out the door.
   / BX25D? #7
I have R4 tires and mow with it. I think they are a better choice for a tractor equipped with a loader. If you don't cut a sharp turn on wet grass running 5MPH R4 tires will be fine as for a mower.
You can get the lights through Kubota as a option. If you can do a little wiring and fabrication you can make your own ROPS lights. I would buy the fender mount lights from Kubota.
Sent from my Samsung SPH-L710 using TractorByNet
   / BX25D? #8
It's not necessary to limit yourself to turf tires if you're thinking of mowing with it. I have a BX25 with R4s and mow a nice lawn with it weekly from May to October. They'll leave a mark in the occasional soft/wet spot, but the impact is minimal, temporary, and nothing that's ever affected the appearance of the lawn. I've also found them to be reasonably good (good enough to get the job done, anyway) when doing snow removal with the FEL.
   / BX25D?
Agreed the industrial tires are preferred for loader jobs. I do worry a bit about the lawn, but I appreciate you sharing your experience.
I will add the fender mount lights and build the ROPS lights. Thanks!
   / BX25D?
Thanks for the +1 on the industrial tires for lawn mowing. I'm feeling more confident now, which means I should probably consider adding the deck....or maybe wait 'til the spring to add the deck.
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A51039)
John Deere 6105E...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
2018 Ram 5500 Bucket Truck 4x4 with Versalift VST40 - 45FT Rotating Bucket and Jib Winch (A51039)
2018 Ram 5500...
John Deere TX 4x2 Utility Gator (A49346)
John Deere TX 4x2...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2020 Freightliner Cascadia 126 T/A Sleeper Cab Truck Tractor (A49461)
2020 Freightliner...
