Can I trailer this tractor
   / Can I trailer this tractor #21
I 2nd the worry on the diamond plate, most trailers I have seen have angle iron "slats" so you are driving on the ^^^^^^^^^^^ instead of on the diamond plate _____
You might try hand sprinkling sand onto the wet paint? I dont know how long it would last.
   / Can I trailer this tractor #22
You can also weld some expanded metal over the diamond plate. I have seen this used on other trailers and it seems to work well.
   / Can I trailer this tractor #23
Seems like that would just hold dirt and snow.
Chris
   / Can I trailer this tractor #24
what is this snow stuff? that you are refering too? LOL us Florida boys know not of what you speak!
   / Can I trailer this tractor #25
I was thinking about your trailer and the cheapest most effective way I can think of to add a non slip other than paint on a non skid paint is to weld 1/2" Rebarb every 5" or so across the metal tail. It will not hold dirt and will give you plenty of grip.
Chris
   / Can I trailer this tractor #26
Nice trailer...I dont think your overweight at all.In fact your setup should tow perfectly....your only overweight by the GM trailer rating which is low,and for warranty only.It is not DOT enforceable,you are fine,enjoy your setup.
   / Can I trailer this tractor #27
It seems that you and I are the only ones that know this. :confused:
   / Can I trailer this tractor #28
What do you suppose his insurance company would say/do if he has an accident? I'd bet they'd be lookin' at the stage door left....
Good luck with that!
AKfish
   / Can I trailer this tractor #29
I went ahead and got a Gooseneck. It is a 8' x 20'+4' dovetail with two 7k axles with brakes. I bought it used, it is a 2005 (year) model and made by Black Brothers....never heard of them but the trailer seems to be made nicely. I was really impressed how well the trailer pulled behind my 3/4 ton Chevy and was alot more stable then a 10k bumper pull that I borrowed. I know I'm overweight with this trailer, like Diamondpilot said, " this trailer is half my tow rating," but the 6.0 gaser didn't strain to much and there isn't any mountains here and now I have a bigger trailer for when I upgrade my truck. Thanks for everyones input............Mike
Very nice set up. Goose neck pulls great, really the only way to go.
   / Can I trailer this tractor #30
mlitt,
The GM trucks can be a little confusing. You could have 3 trucks with three very different rear axles, all bearing the "2500" designation in 2003. I believe 2003 was the last year GM had the option of the regular 2500.
The regular 2500 has the same drivetrain as all of the 2500s did dating back to 1988 (disregarding the minor changes in the chassis). They have a 8600 lb GVWR, 8.825 " ring gear front axle and 14 bolt semi floating rear (9.25" ring gear I think). Spring ratings were similar.
The 2500HD's with 6.0L gas engines have a GVWR of 9200 lbs, have a larger front axle (don't know the size) and have the bullet proof 14 bolt full floating rear axle (10.5 " ring gear). An interesting note is that the newer 14 bolt FF's do not have the pinion gear snout bearing like the old axles had. Gears are not interchangeable, even though they look identical. Spring rates front and back vary by package, but are generally stiffer than the regular 2500.
The 2500HD with the Duramax diesel or 8.1L gas engines are the same as the 2500HDs with the 6.0L gas engines, except the transmission options (which have been beaten to death in many other threads and other forums) and the rear axle. The rear axle for these was designed and manufactures by AAM, is a full floating type with a 11.5" ring gear.
Add to that, the various suspension packages, like the towing package, snow plow prep, etc and you have a lot of variables in the exact towing and payload numbers. When you have trucks at the opposite ends of the "2500" spectrum, its not unreasonable to see the huge difference in payload and towing numbers.
CATERPILLAR D6T XL CRAWLER DOZER (A52709)
CATERPILLAR D6T XL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
16' WAGON FOR HAY TIRE ROAD STYLE (A52708)
16' WAGON FOR HAY...
John Deere 5103 (A53317)
John Deere 5103...
2025 BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
