sparc
Veteran Member
- Joined
- Oct 2, 2011
- Messages
- 1,093
- Location
- NJ
- Tractor
- JD 4410, NH TC-25, Bobcat M610, JD X534, Dig-It Model 158, JD Ztrak 737. 6X4 Gator
My JD PHD200 has the power down option.
I was looking at it today and thinking I will not use the PHD that often, at least not as often as I will use the 3ph for other attachments.
I was looking at that hydraulic cylinder and my top link and thinking they are about the same length and have about the same adjustment range.
I checked and the pin sizes are the same.
So it looks like if I added a third hose with the correct quick connect I could use this cylinder as a hydraulic top link and when I need it on the PHD I can transfer it over there and use it for drilling holes.
Am I missing something or will this work? Is the seal in the hose which is not connected good for the pressure it will see when not connected? I would want to damage it or have it leak.
The way it works now on the PHD the one hose extends the ram, the second hose is piped to dump back to a common return. When the PHD is raised the down assist cylinder is compressed and the hydraulic fluid id dumped in the return line.
First photo shows the plugged side of the piston where I would put the third hose for use when connected as a hyd. top link.
Second photo shows the relief valve and return line.
Last two photos show the return connection on the tractor and the rear hydraulic connections.
Anyone tried this?
Anyone tried this?
