Can you stop the beeping?
   / Can you stop the beeping? #21
bondo said:
If I remember right on my TT50 I found that sucker at the fuse block. It is a black very thin square attached to the relays. All I did was put black electrical tape over the holes and you don't hear it. I tried to remove it, but it caused another problem, just don't remember what that was. The tape works great!
Good luck,
I recall the beeping sound coming from around the fuseblock, but I could never locate it. Sure makes a lot of noise for a little square.
When the weather warms up a little...I'll take the cover off the fuseblock and take care of it for good.
I guess we have OSHA to thank for that irritating little device.
   / Can you stop the beeping? #22
Oh man, I HATED that beeping... So I just jumped my seat switch, not the best if your concerned about safety, but it suits me just fine...
Max
   / Can you stop the beeping? #23
Nice photo. When I tested the switch, I thought it connected the inner two and the outer two terminals seperately when pressed, although i think on the tractor side, the hot sides are coming from the same source, so it probably does not matter. I know the inner pair controls the shutdown and the outer pair controls the beep.
Jim Frisby
   / Can you stop the beeping? #24
I eliminated the switch early on but it did not stop the beeping. Disconnecting the little noise maker did though
   / Can you stop the beeping? #25
I for one think companies have gone a bit over board on some of the saftey devices. I purchased a Cub-Cadet about 18 years ago and it had a switch that would stop the mover deck when you backed up. I think I hadthe tractor 5 minutes before I went into the house, found some wire and defeated that saftey "feature". I cut 25% of my grass in reverse. Now the seat saftey switch is still working. Hasn't been a isssue till my nephew wanted to cut the grass. If he sat too far forward the mover would quit. The tempory fix for that was duct tape.
Wedge
   / Can you stop the beeping? #26
Consumer product safety laws.. IE.. CYA for the manufacturer.. etc.
soundguy
   / Can you stop the beeping? #27
soundguy
I understand that. But aren't we just defeating the darwin theory with all these safety features? Maybe this is why common sense is lost in America.
Wedge
   / Can you stop the beeping? #28
Wedge
Does Product Liability come to mind?? Why do you think ATV's and the like are so expensive. It's not manufacturing...it's Product Liability. ATV's are one simple example of this.
   / Can you stop the beeping? #29
That was my point.. companies doing CYA..
and yes.. we are defeating the darwin stuff.... and letting in some cases.. some prettty clueless people breed... gotta make sure the dumb genes get passed around! ;)
soundguy
2012 Keystone RV Montana 3625RE 38ft. T/A 5th Wheel Travel Trailer (A55853)
2012 Keystone RV...
2015 Chevrolet Impala Sedan (A55853)
2015 Chevrolet...
2013 Ford Taurus (A56859)
2013 Ford Taurus...
2016 Cat TL1055D Telehandler (A55315)
2016 Cat TL1055D...
Longhorn Steer Skull Art (A55853)
Longhorn Steer...
2015 Dodge Journey Van (A55853)
2015 Dodge Journey...
