gsganzer
Elite Member
- Joined
- Jun 11, 2003
- Messages
- 3,049
- Location
- Denton, TX
- Tractor
- L3800 w/FEL and BH77, BX 2200 w/FEL and MMM
You might be amazed how flimsy the locking apparatus is if you remove the door interior and look at it. I put a new lock on my Browning safe and I was shocked at how crappy the rack and pinion linkage was. There were multiple points for eminent failure and misalignment. It's a simple apparatus, so I fixed all the areas of concern when I put the new lock in.Sounds like the locking mechanism might be causing trouble. On my Home Safe, I had a similar issue where the handle turned but didn’t fully retract the bolts. Turned out a little lubrication on the internal linkage helped smooth things out. If that doesn’t do it, carefully removing the inside panel to check for loose or misaligned parts might be the next step. Sometimes, a slight shift can cause binding.
