Carryall Build with Photos
   #1
Trails2004
Outside
2009 JD 3520
Last weekend I built a carryall. First I painted the frame then I stained the planks and assembled once dry- OK almost dry :eek:
Other accessories will be added soon ;)
Materials:
2 x 8 rough sawn planks
Alot of carrigage bolts- I think 48 in all :cool:
4 flush mount "D" rings- 1200 lbs cap
4 bolt on "D" rings 5000 lb cap
2- 5000 lb Clevis hooks
Note the flush mount "D" rings will be used to bungee or strap shovels, picks, and other hand tools against the back of the carryall. The bolt on "D" rings and clevis hooks are in place to lash down the load.
beenthere
Super Star Member
Southern Wisconsin, USA
JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
How did you set the D rings? Hole saw first? Or large forstner bit?
johann
bx2200
Nice work! I like it. I am going to build a carryall my self hopefully before spring, I like seeing what every one comes up with.
p.s. do you armor all your tires? JD looks wicked clean!
OP
T
Trails2004
Outside
2009 JD 3520
A hole saw and a chisel- just a couple minutes per "D" ring. I also sealed the wood and a thin bead of adhesive around the flange.
OP
T
Trails2004
Outside
2009 JD 3520
No armor all :D After I purchased the tractor I took it to the car wash a few times. Right now the tractor is a garage queen while I complete a few projects- My wife tells me that will change- I guess she is tried of scraping the frost off her windows in the morning :D
Bedlam
Veteran Member
She sounds like a keeper. (wife that is) LOL
Runner
Veteran Member
Missouri
John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
OK, this is driving me nuts. For some reason, I can't see the pictures in any of Trails2004's posts. Does anybody else have this problem? Solution?
