As the title states, I have a Massey GC1710. I was given a woods RB-5, rear blade. The blades 3PH mount is 19" between the pins, making it a cat 0 I beleive. Can I use this on my cat 1 hitch for snow removal?
I believe cat 0 pins are 3/4 and cat 1 are 7/8 but lift pins are not that expensiveIt may have smaller diameter pins on it, depending on whether it was design/used as a true Cat 0 or as a limited Cat 1. Bushings or replacement pins can fix that.
Bruce
Your top link pin will be 3/4The pins were throwing me off somewhat as the lift pins are already 7/8, I will have to try to get a bushing for the top pin though, as that is 3/4 and a 7/8 pin will not fit through the holes. Thanks for all of the input.
