Oil & Fuel Checking hydraulic fluid
   / Checking hydraulic fluid #1
radnack
NY
TYM T451
Hi i have a TYM T451 and ive tried checking the hydraulic fluid on it and i cant seem to get a consistent reading on it. Ive parked it in the same spot twice and different readings each time? Ive had it all the from empty to full. Its parked in the most level spot i can find as well. It had a dipstick if that helps. Any idea on which reading i should use or what would be causing this?
   / Checking hydraulic fluid #2
When checking the fluid, make sure you have the loader on the ground and the 3 pt lowered.
If you leave the loader in the air, the dipstick will read empty.
BINGO i put the loader down and it was full! Thank you so much!
Adams Conveyor (A51039)
Adams Conveyor...
2015 JOHN DEERE 35G EXCAVATOR (A51242)
2015 JOHN DEERE...
2021 JCB HM180T Hydraulic Breaker Excavator Attachment (A49461)
2021 JCB HM180T...
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A51039)
Morooka MST 660VD...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
